Question about Braun Syncro 7526 Electric Shaver
What does the flashing yellow light mean during charging on my braun 7526?
  • 5 Answers
SOURCE: Braun 7526 battery problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Posted on Jan 07, 2009
Cytherian
  • 124 Answers
SOURCE: My Braun 7526 razor will
This happened to me as well. Often the batteries will last longer than the rest of the shaver. You can obtain the batteries as cheaply as $12 a piece on "that auction site."
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Posted on May 23, 2009
Cytherian
  • 124 Answers
SOURCE: Braun 7526 not charging the + light wont turn on?
In your case, it's hard to know exactly what might be wrong without more information. Was the shaver perfectly fine and then all of the sudden won't turn on? Or was the shaver working for shorter and shorter periods over time and then just quit? Was it exposed to undue heat, such as left in a car or in a place that wasn't air conditioned in the hot summer?
Although the batteries in these shavers are fairly robust, if fully discharged and not used for a long while, it might be that they've got a "low level memory" and will need replacing. If you are handy, you could disassemble the shaver and replace the batteries. They are NiMh AA flat top batteries that you can buy on websites like onlybatteries.com. If you're handing with soldering, you can replace them yourself. If you're unsure about that, you can buy the batteries along with the circuit board as a complete unit that drops right into place. Shaveroutlet.com sells these.
Another thing is that if the shaver was dropped, there's a chance that a metal connector part has come loose and so the shaver won't function. Taking it apart, you can see if this is the case.
The Braun 7000 series are rather old at this point, so sending it off for repair is kind of out of the question, as the costs involved would be more than if you bought another shaver. If you're not wanting to spend the big $$ on the new 9000 series shavers, find a new old stock 8000 series shaver (they are better made than the 7000 series). You can search on "that auction site" and you'll find quite a few Braun 8000 (or 360) series shavers available for sale.
Posted on Oct 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: braun 7526 trimmer will not move to the up position
The trimmer is extended by the button on the opposite side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
vetteman3002
  • 2299 Answers
SOURCE: hi, My braun bs 5301 does
Check to make sure that the shaver and the charger are clean. It is not locking in because there is something that is not letting it go down in far enough. You can clean it with canned air.
Posted on Nov 05, 2010
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
My Shaver will not charge or turn on
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model
If you like this shaver model and want a similar one, you will find one at shaveroutlet.com. This model uses the same shaving head as the 7526
http://shaveroutlet.com/braun-series-1-195s-mens-cordless-shaver.html
Oct 27, 2014 | Braun Syncro 7526 Electric Shaver
Braun trimmer #7526
Most likely, the batteries are dead and need replaced. You need two batteries and they can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
For installation videos, see links below
http://www.youtube.com/watch?v=D6jRpCnB8T4
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Jan 09, 2014 | Health & Beauty
Power cord
braun 7030458 syncro shaver charging cord for electric razor braun 7526 adapter power cord replacement parts.
Jun 01, 2013 | Braun Syncro 7526 Electric Shaver
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
94 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
