Ovens Logo
A
Anonymous Posted on May 11, 2014
Nardi oven child lock - Ovens
How do you turn of the child lock button
For every oven with a child lock ever made?
'make mode (what is is)' in all questions, first 3 words.
Google
make model turn off child lock
https://www.google.com/search?q=%E2%80%8Bmake+model+turn+off+child+lock
Dec 16, 2023 • Ovens
I have a Sholtes oven FI6326 THE DOOR IS BLOCKED AND CANT BE OPEN
Was the child safety lock accidentally set?
Child safety device
The child safety function can be used to lock the oven
controls.
To activate the child lock, press the
ACTIVATE and press "OK" to confirm. To deactivate the
child lock, follow the same procedure but select
DEACTIVATE. The child lock may be activated whether the
oven is on or off. The child safety device may be deactivated
when the oven has finished cooking and in all situations
described above.
Oct 02, 2020 • Ovens
1helpful
2answers
Nardi model ek95583ax. Where can I get a manual?
Contact Nardi directly to request the manual.
Jul 16, 2020 • Ovens
My aeg oven has a child lock feature which I can't turn off could you please help
Which model do you have? For the AEG Competence B9820, you toggle the Child Lock on and off by pressing and holding the Selection Clock and - buttons simultaneously until the Child Lock changes state. See https://www.manualslib.com/manual/611343/Aeg-Competence-B9820-4.html?page=45 . For the BE7314401, press clock and down arrows for ~2 seconds until you hear a chime and the lock turns on or off. https://www.manualslib.com/manual/444474/Aeg-Be7314401.html?page=22 has the details.
Please add a comment with the model number for direction specific to your oven. I will attempt to determine if there is a different combination to enable or disable the child lock feature. Note: at least one AEG microwave/grill uses Press "Micro+Grill" once. Then press "Clear/Stop" 5 times to toggle the child lock on and off.
I hope this helps.
Jan 06, 2016 • AEG Ovens
Nardi oven F86
I have a Nardi f86 but I Don't know how can I used the Bud ( knob ) of the furnace, please can you help me, thanks verf much, greetings of ANNE
Jun 03, 2013 • Ovens
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 • GE Ovens
Nardi FE46 electric oven short
it appears that there's a short in the oven. When you turn it on is when the short happens and in order to properly determine what is wrong then you are probably have to call a service tech./
Dec 23, 2008 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
