Question about Coleman Powermate 200 Watt Compact DC/AC Power Inverter # PMP
Coleman 800 Watt DC Inverter Smoked... Need Repair Manual ASAP!
While using my Coleman 800 (1600 peak) watt DC power inverter today, it started smoking inside. I quickly disconnected it from the battery in the car & reconnected it a few minutes later. It still smoked with no AC output.
I need the repair manual for it ASAP so I can troubleshoot, diagnose & repair the problem.
Where can I find the schematic manual online for download? I had a site for free manual downloads but lost track of it. I think it was something etechnotes.com, I had to register and it saved my manuals to my free account. Ever hear of it or something like it?
Thanks, in advance.
SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Posted on Sep 01, 2008
SOURCE: lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
Posted on Dec 31, 2008
  • 252 Answers
SOURCE: need manual for my Coleman Powermate generator
Get model number and go to: http://www.powermate.com/productmanuals.php?cat_id=3
Posted on Mar 11, 2009
  • 12 Answers
SOURCE: Low voltage output from inverter
Ignore peak, that means nothing. RMS * 1.414 = peak. RMS is the actual usage you will get, thats all. Peak doesnt mean it will supply the peak wattage for a short period of time: salesmen with no electrionics training tell people this and its a big fat lie.
See what the unit is drawing, use a clamp-on ammeter on ONE lead (not both, or it will read 0). That shoudl tell you if your device is drawing too much. You should only be able to run that device UNDER the 800 Watts (watts = volts * amps, not including loss of efficiency which might be 10% or more, and even greater when warm)
Source: I'm a maintenance electrician. Like the home-builder kind, same apprenticeship (more hours; 10,400) but also with much industrial training in PLCs, transformers, converters, inverters, motors, controls, etc.
Posted on Mar 31, 2009
SOURCE: 5000 watt coleman generator. Starts but no power.
engine starts & runs but no power.checked breakers ,theyre not tripped
Posted on Mar 01, 2010
Running my HP laptop computer on a 12dcv to 110acv power inverter
If you are worryed about that,, then just unplug the laptop before you turn over the car. What you have should be ok.
Nov 25, 2015 | HP Electronics - Others
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
Does peak 100 watt inverter have a fuse inside? It is brand new & i can't make it active.
yes it does have a fuse inside where you plug it in the lighter should have a metel tip on the end will be spring and fuse inside behind metal tip
Jul 04, 2011 | Peak Performance Peak PKC0AM 100 Watt...
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
Have a coleman 2000 watt 24v dc power inverter. When using it for a short period the temperature light and alarm sounds. The can just be a tv. The watt meter on the panel don't event light up. What the...
If you are only tring to run a TV off this inverter, it appears you may have a defective unit. If you have had this inverter for only a short time, contact the dealer/store where you bought it and seek their advice. If you have had it for 90 days or more you can still contact the dealer, but maybe it would be best to contact the coleman company. You can go to their website nad find out how to contact the division that deals with this particular type of product.
Mar 23, 2011 | Coleman Cable Coleman 1000 Watt Power...
175 watt 350 peak inverter 12v dc to 110 ac need a fuse but don't know what size to use. old fuse is missing.
Hi
15/16 amp would be recommended.
You could to try a 20 amp, but you will risk overheating and the possible failure of the vehicle circuit fuse.
Regards
Jan 30, 2011 | NexxTech 175W Power Inverter
My inverter is in alarm and won't produce 110 power. Checked input voltage and it is correct.
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 26, 2010 | Coleman Cable Coleman 1000 Watt Power...
I attach my inverter with custom battery cables and it powers up. As soon as I plug in an extension cord (any cord)it starts beeping. I don't even have anything plugged into the other end.
please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Nov 17, 2009 | Coleman Cable Power Inverter PMP1200
Coleman Powermate  200 Watt Compact DC/AC Power Inverter # PMP Logo
374 people viewed this question
Top Coleman Electronics - Others Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Coleman Electronics - Other Expert? Answer questions, earn points and help others
