Question about Peg Perego Toys
How to change tires on gator peg prego - Peg Perego Toys
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Pop off the center cap with a flat head screwdriver from both rear tires and then use 2 13mm wrenches to remove the bolts from both sides then pull off the tires
Posted on Aug 15, 2017
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 670 Answers
SOURCE: Where can i take my peg prego for repairs? It will
It probally the reverse switch need to be replaced. You can find out more by going to http://peg-peregoparts.com/
Posted on Dec 24, 2009
  • 29 Answers
SOURCE: Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Posted on Apr 20, 2010
SOURCE: Where can I find rubber tires
I was wondering the same thing, can't find any rubber replacements and came up with a solution- use a rubberized undercoating for automobiles. It sprays on thick and provides more grip than the plastic wheels do.
There is more info on modifications here:
http://kidsbatteryrideontoys.com/gearheads-only/
Posted on May 28, 2010
  • 110 Answers
SOURCE: where can i get a rubber tires for a Peg Perego
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
Posted on Jan 28, 2011
Peg perago ride on toy only one tire has power
Does both wheels make a grinding sound when you turn them by
hand. If so, then you might have a lose wire. But if it does not make
a noise then the motor is no good. Each tire on the rear of my grandson's gator has a motor . The tires are independent of each
other.
Jul 17, 2014 | Peg Perego John Deere Gator HPX Ride on...
Can't find where to plug in the charger to recharge the battery. Can you please tell me where to look on the Prego John deer 4x2
the battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Oct 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
Where can i get a rubber tires for a Peg Perego John Deere Gator HPX 12 Volt Ride on Toy?
Oct 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
My john Deere peg prego will not go in Reverse. How can I fix this?
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath you can order a new one here www.powerwheelsoutlet.com
Aug 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Machine acts like rear tire is locked up. took battery off and recharged with a little jolting the tires turned 2 times
The Peg Perego Gearboxes will lock up when they go bad. It might also be a motor locking up.
I had the same problem with my grandson's gator, so I called the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-gearboxes-and-motors.html
They helped me over the phone and could actually tell by listening to it over the phone.
I would give them a call, just to make sure.
Hope this helps
Feb 28, 2010 | Peg Perego John Deere Gator HPX Ride on...
How do i change rear tires of gator? axle rotates when i try to remove nut from axle.
I would take a pair of pliers and hold on to the axle while a loosen the nut from it.
I had the same problem, but I contacted the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
and they gave me that trick.
Hope this helps
Feb 27, 2010 | Peg Perego John Deere Gator HPX Ride on...
Please let me know how I can change the rear tires of the John Deere Gator HPX 12 Volt Ride Toy
I want to add additional traction to my John Deere electric Gator. I have heard that you can somehow slip a bicycle tire over the plastic tires. Has anyone done this and how do you do it?
Sep 06, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
44 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
