Question about Toto Home
How do you fix the toto washlet wand from constantly dripping?
  • 34 Answers
SOURCE: TOTO Elongated Washlet C100 Toilet stopped heating the water.
no there is not
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Posted on Apr 08, 2009
gary1121
  • 332 Answers
SOURCE: TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Posted on Jun 06, 2009
co7196
  • 3433 Answers
SOURCE: ToTo S300 spray very weak
Poor some clr in the washer bottleand block the nozzles as you run the clr through. they will clear up, but don't leave the clr on your paint or in the washer bottle. Rinse everything out and off.
Posted on Jul 10, 2009
muralme
  • 20 Answers
SOURCE: Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
Posted on Jul 12, 2009
Little water pressure from wand. The pressure does increase and decreasefrom little to nothing and only from one hole.
Try removing tip on wand 9 out of 10 times sand or grit will plug spray orifice
Mar 27, 2017 | Toto Home
I need a Base Plate Template for my toto washlet c100
Wow I need one of those. Never even seen one before. Found a site that has spares luv.
Washlet C110
Nov 03, 2011 | Home
Everything works, but water will not come out of the wand. Changed all filter, checked water lines? Read the manuel, tried all trouble shooting answers.
The supply line running from the junction valve to the seat is kinked or pluged in some other way way. take that line lose at the juction valve and see if you can blow air through it.
Jan 27, 2011 | Toto Round Washlet S300 Toilet Seat -...
The toilet keeps running constantly - the tube in the tank is overflowing and i can not get the dripping sound to stop. Anything i can do?
The noise is because your float in the toilet is set at too high of a level and it is overflowing and making noise.
Reset your float, to adjust the water level just below the overflow pipe...this should stop your noise.
If it does not correct the problem then you will have to replace the water control unit inside of the toilet tank.
Please rate me
Dec 05, 2010 | Toto Washlet Elongated Toilet Seat Bidet
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
How does one replace the seat on a Toto Washlet model SW824?
two screw if you look in frent botim of tank that you flush normally plastic open and the seat will come off and you put back the new one the same way back
Aug 05, 2009 | Toto Washlet S400 for Power Gravity...
Toto Washlet weak
Jul 02, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
TOTO WASHLET LEAKS!
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Home Logo
42 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
