Question about Western Digital Caviar SE 120 GB Hard Drive
Blue light powers on but it's not recognized by my mac.
When I plug in my external, the blue light powers on, I can feel the it vibrating from the disk rotating but it is not recognized by the computer, I tried using another USB cable that I know for certain works, as well as tried a different external on my computer which worked, and tried my external on a different computer which didn't work so I know for certain there is a problem with the external and not a glitch with my cable or computer.
  • 147 Answers
Your external casing might have some problem.Replace it with the new one.I think your hard disk is ok.
Posted on Jun 23, 2009
Silicon power a80 has all my movies on it from my mac book but now i try plugging into my tv or blue ray player and router and nothing will recognize it
A: Does your tv have a usb port and drivers to recognize a hard drive? WE don't know you did not provide that information.
B: Same for your Blue ray player
C: Same for you router
D: Mac file system is not the same as Windows file system
Mar 25, 2014 | Silicon Power Armor A80 1 Terabyte 1TB...
My macbook pro doesnt recognize my toshiba canvio 3.0 external hard drive
When have you bought you mbp ?
Your External HDD is in which format, Do you have an app like NTFS for mac osx, or Tuxera NTFS on your MBP if your HDD is not formated as MAC OSX drive. .....
Nov 30, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
I just bought the Portable Super Multi Drive from LG GP08 Lite. On the back of the box, it says that it's compatible with Mac OS X v.10.5.4 or higher, which I have, so it should work. However, when I...
Hi there! First we have to make sure the drive has power. As soon as it is plugged in and turned on (if it has a switch) you should feel it vibrating lightly. Once you feel it vibrating and it is plugged into the computer go to your Applications folder, then to Utilities. In there is a program called Disk Utility. Open it and in the column on the left you should see your drive listed. Click it and select "Erase" from the tabs on the right. Make sure that you select "Mac OS Extended (Journaled)" for the Filesystem then click "Erase." Should work great after that. Keep in mind that if there was any data on it then it will be erased by doing this. If you do not see the disk in the column on the left, then the drive is most likely bad and should be returned.
May 23, 2011 | Computers & Internet
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I have an HP 1TB External Hard Drive, but it won't connect to my computer. A blue light continually flashes on the drive when the USB and power source are plugged in. I don't know how to fix this problem....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
All the best.
Jan 08, 2010 | Computers & Internet
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
Hard Drive not powering on
kschamu here is the only fix for you you need to go out to best buy and get a external hard drive shell and go into your external and remove the disc and put in in the new shell
Sep 03, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
MyBook's power light is blinking, but not showing up on my Mac's desktop
Data recovery usually will cost about 2000 - 3500. i may be able to help as long as the platters aren't physically damaged. Send me the drive at your cost. I will pull all data and return data on burned dvds I keep the drive. If i can't retrieve data then i will return drive to you at my cost. jprusso@yahoo.com
Jun 01, 2008 | Western Digital 320GB MyBook External USB...
Western Digital Caviar SE 120 GB Hard Drive Logo
176 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
