Question about Ovens
Kenwood ck 404
Gas ring won't light
The self gas ignition stays on and keeps clicking.
Request manuals and parts lists directly from Flavel.
Nov 04, 2017 | Stoves Ovens
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
I replaced a heating element but the oven still won't light
is this gas or electric?
you are using terminology of both, but not specifying which it is..
if gas you could get a thermocouple at your local hardware store or home depot..
If electric, test the switch with a multi-function tester
Best regards
Ck
Aug 18, 2011 | GE Ovens
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
Bought new cooker however no user guide its a kenwood ck404 duel fuel double oven 5 ring burner. need to know what symbols on switches are and what they do.
I have a problem with my Kenwood CK404. When I put either oven on (it's a double oven), once it gets hot it starts to make an awful noise. At first I thought it was the fan in the main oven. But it makes the same noise in the small oven, which doesn't have one. Does anyone have any suggestions of what the problem could be? Kind Regards
Trotwood
Aug 21, 2010 | Ovens
I have a G.E. self cleaning oven, the broiler works however the oven does not
if the unit is gas it may be the ignitor and if elect it may be the bake element . remove either and ck it with a ohm meter . . also ck the house fuse . making sure the power to oven is ok . if broil works power is probably ok ..
Aug 11, 2010 | Ovens
Oven will not ignite because the gas is not coming out.
not a good way to light the oven . so do ck for the loose connection . as cooking will be much easer.. if gas ck the ignitor and if elect ck the connections on range pig tail ( power cord ).. mm hope t this helps...
Jul 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Kenwood cooker
It seems to me that your oven has a thermo couple which is faulty. this needs to be repalced. This part control the gas going into the oven if faulty it will go out.
Most ovens have ffd or fsd, however im fairly sure yours is a neither of these and is a thermocouple.. hope this helps..
Dec 24, 2007 | Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
