Question about Refrigerators
Fr-581nw What is the annual energy consumption?
3 Suggested Answers
  • 55 Answers
SOURCE: Energy consumption of 1.5T LG intelloair split A/C
your energy consumption will be the exact same the capacitior does nothing to alter your systems operation. a capacitior is a voltage absorbing unit that provides ample power for a mechanical device when it starts. the only way to lower your energy consumption from the largest appliance in your home is to buy a more efficent one with a high SEER or EER rating.
Posted on Sep 21, 2009
  • 42 Answers
SOURCE: could you tell me the average annual energy
sorry but your would need to check gas meter dial when hob is fully on also length of time it is used for.
Posted on Sep 30, 2009
I'm going to buy a new motherboard...... i found two interesting motherboards Msi x79 Bigbang xpower2 and msi z97x gaming 5 wich one is better and wich cpu should i take i7 4930k or i7 4790k !!!
I'm a MSI guy myself. I would go with the Z97. As for the processors, I would save the extra $150 to $200 and get the 4790k. Plenty of power, and you save some money on it. Use the left overs to purchase a good set of ram. Intel Core i7 4930K vs 4790K
Has a built-in GPU Yes vs No Somewhat common; A separate graphics adapter is not required Higher clock speed 4 GHz vs 3.4 GHz Around 20% higher clock speed Higher turbo clock speed 4.4 GHz vs 3.9 GHz Around 15% higher turbo clock speed Lower typical power consumption 71.5W vs 105.63W More than 30% lower typical power consumption Better PassMark (Single core) score 2,535 vs 1,995 More than 25% better PassMark (Single core) score Better cinebench r10 32Bit 1-core score 8,785 vs 6,903 More than 25% better cinebench r10 32Bit 1-core score Higher Maximum Operating Temperature 74.04 °C vs 66.8 °C More than 10% higher Maximum Operating Temperature Better performance per dollar 4.97 pt/$ vs 3.93 pt/$ More than 25% better performance per dollar Newer Apr, 2014 vs Jul, 2013 Release date 9 months later Lower annual commercial energy cost 77.09 $/year vs 113.88 $/year More than 30% lower annual commercial energy cost Lower annual home energy cost 21.2 $/year vs 31.32 $/year More than 30% lower annual home energy cost
Jan 13, 2015 | MSI Computers & Internet
North Texas Measurement Association and Atmos Energy's 3rd Annual Day of Training
If it is a day that they honor then it is there's and title is correct.
Apr 13, 2014 | Games
Does using dimmers increase power consumption?
No, I don't know from where you got the idea. Dimmers are actually used to reduce power consumption and thereby being energy efficient. Dimmers actually take advantage of the AC current flowing to it and will rapidly switch on and off the current. This happens so fast that you won't recognize power being on and off. This way dimmer switches save power. But to get the real benefit of a dimmer you must change from incandescent lights to CFL. You can actually expect to save about 25-40% of the energy normally used if you dim the bulb to 50% brightness.
Dec 19, 2013 | Electrical Supplies
Want to know water and energy ratings of WFL2000AU.
Here you go, probably more than you wanted J
Energy Consumption per Wash: 190kW/yr warm wash
Water Consumption per Wash: 72.6l
ApplStandard AS/NZS 2040.2 (2000)
Brand BOSCH
Cap 6.50
CEC_ 190.00
Cold Wat Cons 72.60
Conn_Mode Cold
Country Thailand
Depth 600
Height 820
Hot Wat Cons 0.50
Model No WFL2000AU/WFL2080AU, WFL2400AU
New SRI 4.39
New Star 4.00
Prog Name Cotton 40C, 1000RPM
Sold_in Australia, New Zealand
Test Prog Time 123.60
Tot Wat Cons 73.10
WEI .658
Mar 07, 2011 | Bosch Washing Machines
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
What is the energy star rating
Annual Energy Consumption: 186 kWHrs Energy Efficiency: Energy Star Compliant5.0 rating
Nov 22, 2009 | Miele Novotronic W1918A Front Load Washer
Sep 18, 2009 | LG Heating & Cooling
Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Mar 28, 2008 | Refrigerators
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
