Two people above are retarded. It's a well known issue that M$ is too lazy to fix. Technically , closing programs that are using files/folders on the usb should work, but 99% of the time it doesnt work. Your best bet is to shut down windows, then unplug the usb device .
yes I can help, your hard-drive is still in use, ie. close windows that relate to you using this drive like programs or if you were searching for files, close these windows and programs so you can safely remove hardware
I have a WD my book, 500GB. I am running Vista Home 64 Bit. At restart it takes forever. Today I...
(More)
I have a WD my book, 500GB. I am running Vista Home 64 Bit. At restart it takes forever. Today I disconnected the WD MyBook and it immediately starte. It sounds like a driver at startup issue. If i reconnect the device, I see all of the partitions and they behave fine.
I have wd5000aaks driver which was working properly. Suddenly the vista can see the driver but...
(More)
I have wd5000aaks driver which was working properly. Suddenly the vista can see the driver but request me to format the hard drive
