Question about Iomega eGo Portable Hard drive 500 GB external 25" HiSpeed USB 5400 rpm buffer 8 MB USB 20
Incorrect function initialized disk
How to take the data from the HDD
    Scholar:
  • 74 Answers
There are a few steps that you can attempt. Such as using diskpart to try and reformat the drive. Or trying to remove the hard disk carefully from the enclosure then putting the actual drive in a desktop computer and seeing if it is recognized and able to be formatted.
Most of the time when I have dealt with this issue. Sadly the only solution has been to RMA the device becuase there is nothing you can do to fix this issue this internal issue.
The only way to now retieve your data is to seek a data recovery service which will most likely be expensive. Especially if the data recovery service is a real data recovery service. Make sure to ask about the recovery process and how they specifically retrieve the data. If the company says that they actually remove the HDD platters from the old drive to recover the data, you are probably talking to a real recovery team. Rather than a company that will only try connecting a cable and running some software.
Posted on May 23, 2014
Risk of losing data by re-booting CD-ROM recovery disk
Copy off your data to another computer before recovering. A recovery usually restores to factory settings and loses all data.
You could boot to Ubuntu or Linux and copy your stuff that way, then when restored, copy it back.
Feb 11, 2016 | IBM ThinkPad Computers & Internet
Unable to open Hard disk drive
try running a check disk to check for errors. In windows command prompt type chkdsk C (substitute C for the letter of the drive).
Has anything happened to these drives such as dropping that would cause it to not be readable? What format is the disk FAT or NTFS?
Hit us up at our techie forum:
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Western Digital Computers & Internet
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Error sc 870
One possibility:
Address book data stored on the hard
disk was detected as abnormal when it
was accessed from either the
operation panel or the network.
?? Initialize the address book
data (SP5-846-050).
?? Initialize the user information
(SP5-832-006).
?? Replace the HDD.HDD defective
Secondly:
When the machine reaches the Ready condition after boot-up, the operator turns OFF the Main Power
Switch without first pressing the Operation Switch. As a result, the flash memory on the controller board is
damaged, triggering the SC.
SOLUTION:
1. Please be aware of the following:
Before turning off the machine's main power, always make sure that the Operation Switch LED is not
lit or blinking. By turning the Main Power OFF while the LED is still lit or blinking, may cause damage to
the machine's hard disk or memory.
Feb 22, 2013 | Ricoh Aficio Mp3350b Digital Copier...
I have a problem with my LG External HDD HXD5. It's installing on my system (windows) but I unable to access. The computer is asking m to initialize the disk and I wondering to lose all my data
HI,
in the past i have used GetDataBack program utility and worked fine. Before that you could also try HDD regenerator to check and fix any error on the disk.
Marco
Jun 24, 2012 | Computers & Internet
Hard disk is unable to read.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this hard drive recovery program called asoftech data recvoery to recover your files.
http://www.asoftech.com/adr/
Aug 24, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Lg external hdd drivers
If you have an external hard drive, the Windows O/S should have no problem seeing it as just what it is. Now if it hasn't been formatted, you will have to right-click on "my computer" and chose "manage." Then click on the disk storage (left side of the window) and see just what the computer thinks the hard drive is. You may have to initialize the disk. You right-click on the unknown disk and choose to initialize it. var fctb_tool=null; function FCTB_Init_53b6b40ed16348b49cdf9315f99f6bd0(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_c816bf7540af44a6b5615e5055f74f6c(t) { fctb_tool=t; start(fctb_tool); }
Jan 12, 2011 | Computers & Internet
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
Biostar Motherboard p4m800-m7a
You may have a HDD Problem Diagnose it using the following. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 23, 2007 | Biostar P4M800-M7A Motherboard
Again reloading(restarts)
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Microsoft Windows XP Professional With...
Iomega eGo Portable  Hard drive  500 GB  external  25"  HiSpeed USB  5400 rpm  buffer 8 MB USB 20 Logo
66 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
