Question about Rival IR600 Iron
Rival IR605 iron
Where is the screw to disaasenble the iron
How do i open screws
broken studs for screw tightning,cant repair without expert,there is one screw under main wire side,second is under pressure knobs to open it
Dec 18, 2014 | Philips Gc2910/02 Powerlife Steam Iron,...
Where is the setting mark on a rival steam iron #es280?
I believe the cotton settings are often in the middle or slightly hotter.
May 17, 2014 | Rival Irons
Rival IR600 Iron Does not turn on, not heating or lights on ?
see this causes, and use the common sense.God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Sep 19, 2012 | Rival IR600 Iron
Does not turn on
please see the causes and use the common sense. God bless you
I bought a Rival Iron Model # IR999 but, the iron had no instructions in the box. I would like to download the instructions if possible. Thank you, Barbs
The manual for the Rival Steam Wave Iron, IR999, is available here: http://www.rivalproducts.com/product.aspx?pid=2307 . The link to the PDF is below the picture of the iron.
I hope this helps.
Mar 10, 2011 | Rival IR810KS Iron
Hi Our Breville IR80 iron needs its mains cord
If you google 'Security Bit Set' you should be able to find a set of screwdriver bits that will contain one to open the iron. (I think the forked bit in question is called a 'spanner' bit.)
I've just ordered a set from Amazon.co.uk which you can find by searching for 'Screwdriver Bits Torx / PZ / PH / Flat Hex Spline Extra long Security 50pc AT822' at their website.
Nov 01, 2010 | Rival IR800 / IR810 Iron
How to open the back of iron. Has an irregular screw
these screws take a star tip screw driver to remove. My 6 month old Rowenta's switch quit. You can buy the star screw driver at any good hardware store or auto place.
Oct 13, 2010 | Rowenta DZ1700 Iron
How to disassemble a Rowenta DE-871
First remove screw the on the back of the iron. Next pull out on the fill tub on the front of the iron. Pliers might be needed. Another screw will seen at this time. Remove this screw and the sole plate will separate from the top portion of the DE 871.
Oct 02, 2010 | Rowenta Professional DE871 Iron
We do not have operating instructions for this iron...Shortly after setting heat to cotton or linen and iron heats up,,heat screen commences to flash, red light goes out and iron cools as if disconnected...
No,
either the thermostat or a sensor is bad..
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 13, 2010 | Rival IR800 / IR810 Iron
Rival IR600 Iron Logo
48 people viewed this question
Top Rival Irons Experts
ray gallant
Are you a Rival Iron Expert? Answer questions, earn points and help others
