Question about Kenmore Dryers
I have the Kenmore Elite Dryer model #110.60992990. when I turn on the dyer it will run for maybe a minute some times more like 10/12 then it shutsdown I have to restart it severa; times. What is the cause and how can I fix it?sg
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
  • 958 Answers
SOURCE: Kenmore Elite Dryer, Model: 110 60972990... will not restart.
yes, a DIY person can replace a thermal cutoff. just open the rear of the unit and look for parts with big red wires connected to it. it is round, one small and one big. both have two terminal clips.
if you can find the schematics inside the switch panel, then it would help you further. the thermal cutoff consist of two pc. replace both even one of them has continuity.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
huuum
  • 750 Answers
SOURCE: Dryer won't stay on.
tc7059d4.jpg9729365.jpg3403fe5.jpgThe wiring diagram for your dryer is shown in the first image below. A thermal fuse is normally in the circuit to the igniter on many gas dryers. I recommend checking this fuse. On dryer model 11073032102, you can access this fuse by _unplugging the dryer, shutting off the gas supply,_ and removing the bottom front service panel as shown in the second image below. On some Kenmore dryers, you have to remove the back panel to access the thermal fuse. The thermal fuse is located on the blower housing . The third image shows the location and replacement procedure. To test the thermal fuse, remove at least one wire (with the dryer still unplugged) and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms (continuity). If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.NOTE: If the thermal fuse is blown, check the venting for your dryer. Restricted exhaust venting can cause the thermal fuse to blow.
thank You Huuum
Please remember to leave a solved rating before you sign off!
Posted on Jan 23, 2009
garing
  • 998 Answers
SOURCE: My Kenmore ELITE keeps shutting off before the
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Posted on Aug 18, 2009
buffalonyman
  • 1865 Answers
SOURCE: Kenmore 800 Dryer model 110.69822801
replace the timer
Posted on Oct 09, 2009
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
Can I use a 3 prong dryer cord on the Kenmore Elite Oasis dryer?
Most dyers are 220V. If the chord is connected to three terminals as most dyers have, then it would work just fine. Just be sure you connect the ground wire correctly.
Apr 08, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore gas dyer, model 11170092991. Won't start. Control panels lights work. when "start" button is pressed nothing happens
Hi
If your dryer doesn't work or start please check the bellow link to troubleshoot your problem :-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itdoesntworkatall_electric
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Decreasing Timed Cycle Setting in a HE5 electric dryer
I think you need to cancel and restart to change the time to less.
Jan 14, 2009 | Kenmore Elite HE4 Electric Dryer
My dryer wont stay on.
you have a bad microcomputer or as some calls it (even heat board) thats needs to be replaced / if you cant find one contact me with the complete model number from the sticker inside door area and i will see if i cant help you with one / larry
Dec 12, 2008 | Kenmore 63942 Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer
i have had that seam problem 2 times, i had two change te bord 8546219 the 2 times , i don´t know way these hapens
Jun 02, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
339 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
