Intex sub woofer not working schemetic diagram 2600 watt 4.1 speakerboth not working
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
Posted on Jun 17, 2008
dunnbiker
  • 8546 Answers
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
  • 84 Answers
SOURCE: circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Posted on Jun 14, 2009
  • 28 Answers
SOURCE: how do I hook up a sub woofer to my 52wx4 radio. I
You can hook it up a couple of ways.
Depending on how many subs you have and what ohms they are running at here is the chart you need. If your going to run one sub off it the last option is the way to go. Your going to need to find out the power of your subs or else the power could be off and you could blow the sub. If the rms power is higher than 130watts per coil you will be fine. If so there are four channels on the amp and two should show a line going to each other that says bridge. Hook up the positives and the negative of the subs as shown on the amp that will get your max power. If your sub is running at 4 ohm. Let me know, if not thats how you would do it.
Also for the power and remote wires. Hook up a power wire (16 gauge would be plenty fine) from the battery to the + terminal of the amp. Then take an equal or bigger sized wire from the - side of the amp and secure it to any medal part of the body of the car. If there is paint on it get if off. (not on the outside of your car or where any water would be.) Then run a remote wire from your stereo (most the times it is blue and white) to the remote terminal of the amp. This tell the amp when to turn on and off. Your amp will not turn on with out all of these wires. Good luck to you and let me know how it works out.
  • 4 x 55W RMS @ 4Ohm
  • 4 x 65W RMS @ 2Ohm
  • 1 x 130W RMS @ 4Ohm - Bridge
  • Posted on Mar 14, 2010
    Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
    for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
    see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
    you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
    hope this helps :~)
    Mar 03, 2014 | Car Audio & Video
    My Intex 6500 Watts Home Theatre's woofer is not producing its original sound. However, my five speakers connected to the Woofer and doing well and when I put it on 5.1 channel, all the five speakers are...
    The sub is basically an amp in itself. So if you have no sound the main amp inside it has failed. If you can fix it yourself go for the part first that has a heat sink on it.
    Nov 11, 2017 | Audio Players & Recorders
    Circuit diagram 5.1 intex
    MY INTEX 2.1 SPEAKERS BOTH SPEAKERS ARE WORKING OK, PROBLEM IS IN WOOFER, AND THE SYSTEM IS CONNECTED WITH pc
    wHAT COULD BE THE POSSIBLE PROBLEM???
    Aug 18, 2012 | Yamaha 5.1-Ch. Surround Sound Home Theater...
    What is the best way to wire four 6" 55 watt
    My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
    dreamsystems.
    Feb 10, 2011 | Clarion APX490M Car Amp
    QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
    hi,
    Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
    connect the sub woofer pre out of you amp to the pre input of sub woofer.
    ok
    Feb 05, 2011 | Technics SA-EX500 Receiver
    I need circuit diagram for intex IT 2600w multi channel sub woofer
    i need circuit diagram for intex sub woofer
    2600w 4.1 channel
    Nov 28, 2010 | Computers & Internet
    I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
    conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
    Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
    Need help wireing sub
    Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
    Oct 08, 2009 | Car Audio & Video
    Circuit diagram of 1400 watt woofer amplifier
    Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
     Grubhead
    Grubhead
