Question about Onkyo TX-SR606 Receiver
Suffering picture loss
I have an Onkyo tx-sr606 and an older rear projection Sony LCD. I am running all hdmi cables through the receiver and then into the TV. very randomly I lose picture. screen flashes black then turns to static snow then back to black then normal again. Happens randomly and usually for no more than 3 to 5 seconds but is highly frustrating.
    President:
  • Onkyo Master
  • 1,114 Answers
If you must use HDMI, you need to run it directly to the TV from the source for video and use optical or coaxial digital for audio thru your receiver. The problem is HDMI firmware (which is not upgradeable) you have either version 1.1 or 1.2 or 1.2a. All have issues. Three years and running and HDMI still can't get it right! In techno terms it's a DHCP compliance issue (in the real world it's copyright protection) Unless your TV is larger than 50", you can run Component without any visual loss, the human eye can't detect it. Also, if your TV is older, chances are it's 1080i not 1080p, so, if you set your TV to 720P, which is the native resolution of 95% of all TV channels now, and it looks better than 1080i
(1080i = 540p)
I've been doing Home Automation now for 15 years and I've had the luxury of dealing with VGA, DVI, and now HDMI.They have all had issues. Personally I'm just as happy with Component 720P, just use good cables. Hope this helps the pain! If you need any more help, just post a comment and I can help some more.
Posted on Jun 23, 2009
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
I have an Onkyo TX-SR606 connected via hdmi to a Sony Bravia 52" lcd screen. My inputs are a Panasonic DMR-EX77 dvd Recorder and a PS3 via hdmi into the Onkyo. All worked well for a month but now it takes...
The problem is with the HDMI daughterboard in the AVR is bad. This is a well documented issue on this interweb! A general search in google can confirm. Here are some stuff cut and pasted frm their site and another forum. Onkyo USA Corporation (hereinafter referred to as Onkyo) hereby warrants all Onkyo products PURCHASED DIRECTLY FROM ONKYO OR AN ONKYO AUTHORIZED DEALER- WARRANTY PERIOD (from date of purchase) New Products: Receivers 2 years Parts & Labor-- You can go to the Onkyo webpage to find a n authorized service repairman.
*** I took mine to a service repair place today, the guy said that he had two that he just fixes yesterday. He said that this issue has given him a ton of work. Just make sure that you have your receipt from AN UNAUTHORIZED DEALER and that your still under warranty. Receivers 2 years Parts & Labor
Jul 02, 2010 | Onkyo TX-SR606 Receiver
TX-SR606 hdmi ports work when unit warms up? and on screen
Why don't you connect the HDMI cable direct to your tv. For audio run a digital cable to your receiver.
Feb 24, 2010 | Onkyo TX-SR606 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR606 aspect ratio issue
you may want to try changing the aspect ratio on the HD box and the DVD as opposed to the receiver. This should do the thing
Mar 04, 2009 | Onkyo TX-SR606 Receiver
ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Dec 02, 2008 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606 can not get it to work w tv using hdmi cables
try using a HDMI cable connecting the receiver from the "out" to the tv, then allocate through the setup menu what you have connected, say a cable box by hdmi, you would go to cable/sat allocate the port "hdmi1 or coax 1" then return. If it is a dvd click on dvd then allocate eg: "hdmi 2" then return.
Nov 16, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
293 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
