Question about Samsung Computers & Internet
How do i fix my samsung n150 battery shows 100% but not charging
    Top Expert:
  • Samsung Master
  • 8,374 Answers
Sounds like you need to get a new one
Posted on Mar 30, 2015
4 Suggested Answers
aexl
  • 212 Answers
SOURCE: samsung n150 laptop will only
Hi there, it sounds like your battery is no longer functional. You will have to replace your battery in order to get this working again. Before you replace it, ensure that the contacts on the battery and the laptop are clean and connecting - the odds of this being the problem are slim, though. -Alex
Posted on Aug 15, 2011
  • 4961 Answers
SOURCE: samsung n148 not getting charged to 100%
Go into Start, Programs then Samsung folder. The first item in the list is Battery Life Extender. There are two modes, one that charges the battery to 100% and another that is to extend the battery life by only charging to 80% (said to be better if laptop is plugged in most of the time). I put it back on the 100% setting and problem permanently solved. I would imagine if you're having this exact problem that other manufacturers probably have the same kind of settings.
Posted on May 29, 2012
Testimonial: "i find a samsung folder.but when i click it opens Easy display manager and Easy display manager option . confusing pl help"
Geekman
  • 32281 Answers
SOURCE: Why my samsung laptop n150 plus is only charging 80% still i put on charge after 80%?it only show green light after 80% which means that laptop not going to charge after 80%...WHY?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Dec 04, 2012
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
Using while charging?
SURE BATTERYS GET DESTROYED BY HEAT I WOULD RECOMMEND PULLING THE BATTERY COMPETELY OUT IF YOU ARE GOING TO LEAVE IT ON AFTER ITS CHARGED. IF YOU ARE GOING TO LEAVE IT RUNNING FOR A WHILE
May 08, 2013 | Samsung N150 Netbook
Dec 04, 2012 | Samsung N150 Netbook
Samsung n148 not getting charged to 100%
May 28, 2012 | Computers & Internet
When i pull out the power cord on my N150 plus the comp crashes,even though the battery is saying 100 per cent..any idea?
A lot of times this happens when the battery has gone bad and needs to be replaced. It might say 100%, but due to use (and sometimes just due to a faulty battery) the battery will charge less and less and eventually won't hold a charge at all. For example, when I first got my laptop a year and a half ago, I could get almost six hours out of a charge. Now I get almost twenty minutes. Unfortunately, I would say you need a battery. You can get one either from samsung (though you may have to call them, I couldn't find your battery on the site), Newegg.com, or ebay.com.
Some good tips for handling your new battery. First, if the computer's plugged in, remove the battery. Put it back in before you unplug it. This will prevent long-term wear on your battery. Secondly, it's good to regularly (I'd say yearly or so) let your computer "die" on battery (run it until the battery dies), then charge it completely THREE TIMES. This will "cycle" your battery. They say that with the newer batteries used nowadays this isn't an issue, because the new type of battery doesn't create the crystals like the older type does, but it can't hurt anything and I've noticed a difference when I do it.
I'm sorry about the bad news, but hopefully this will help!
Aug 22, 2011 | Samsung N150 (36725723009) Netbook
Samsung n150 laptop will only turn on when plugged in the wall. the charge light flashes green and orange repeatedly , when moving cursor over battery it says 0% battery remaining !! this just suddenly...
Aug 15, 2011 | Samsung N150 (36725723009) Netbook
Hi. I have a prblm in Samsung s5620 monte. The prblm is that my phone showing the charge but it not getting charge. What should i do?
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Samsung Cell Phones
My samsung n150 plus is although plugged in, the battery information describes that "plugged in but not charging"
my samsung n150,although plugeed in charging port displaying not charging..what is the solution for this problem..reply on vvvswathi@gmail.com
Apr 19, 2011 | Samsung N150 Notebook
Battery
please call samsung technical support, if your old battery did get charged upto 100% but gave less backup and when you got this new battery and it shows upto 60% of charge that could mean that the new battery is faulty but the tech support can troubleshoot it better.
Further Queries are welcome
if you think mu solution was helpfull please do rate me
Feb 23, 2009 | Samsung X05 Notebook
Computers & Internet Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
