Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
What is the reason for very low steam pressure from wand and capuccinatore on saeco royal professional
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
Posted on May 14, 2009
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
Our Saeco Royal Professional has been working well but has started ejecting steam out of the steam wand and cappucino spout.
Sounds like your machine needs a new steam valve plastic. Because it is worn the part is allowing steam to come out of the steam wand when it should be closed.
Hope this helps.
May 20, 2011 | Saeco Royal Professional Espresso Machine
I have a Seaco Royal Professional coffee machine and it is telling me to ventilate, what does this mean and how do I fix this problem?
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out. This mean that any steam or air blocked in the water system must get out from steam wand.
Good luck
Jul 26, 2010 | Saeco Royal Professional Espresso Machine
I have a saeco Royal Professional and have noticed that although the steamer appears to have sufficient pressure it is taking longer to heat the milk via the wand and that it appears to be steaming up...
Very good description. The problem is very simple. Inside the machine behind the steam wand the secure nut on the pipe coming to the wand is loose and you can tight it back in place very easy. You will need to remove the top plastic cover to see where the steam is leaking.
There is a chance that the pipe or nut is proken but this is very rair.
Good Luck
Mar 27, 2010 | Saeco Royal Professional Espresso Machine
Steam building up within the unit/
The steam pipe after the steam solenoid to the steam arm is leaking which it can be cause just becase the support nut is loose. So if you just remove the top plastic panel you can even use the machine and see which point need to tight it up.
Good luck.
Remember top vote for this answer
Mar 10, 2010 | Saeco Royal Professional Espresso Machine
I have anew royal professional the milk throther,
Aren't you supposed to foam the milk in a seperate container with the steam wand?
Jul 02, 2009 | Saeco Royal Cappuccino Espresso Machine
No steam at all
I think you have calcium in the tube from the rapid seam element, try to decalcify the machine.
Jun 24, 2008 | Saeco Royal Professional Espresso Machine
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
20 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
