Question about Whirlpool Refrigerators
What are the outside dimensions for a whirlpool fridge, model ED5SHAXMB10
4 Suggested Answers
  • 202 Answers
SOURCE: I have a Whirlpool, model
Hi.... it sounds like the tube that feeds the icemaker is frozen up...
Posted on Apr 01, 2011
woodchuck789
  • 4070 Answers
SOURCE: we have a side by side whirlpool ice/water though
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Posted on Aug 11, 2011
Sea Breeze
  • 4655 Answers
SOURCE: We have a Whirlpool model ED5shaxmb10 that the freezer is working fine and the ice maker works but the fridge portion is not as cool as it should be, it is only 42 degrees at the highest setting
You most likely a defrost problem. Look into the back of the freezer and see if you have frost building on the rear panel like in the photo=> HERE
The most likely part that will need replaced is the=> W10351625 Defrost Control Board
The next most likely parts that may be defective are the=> 2323198 Defrost Heater Assembly
and the=> W10225581 Defrost Thermostat
Like I said the defrost control board is the most likely part to fail and cause defrost to stop working. The defrost control can be found behind the control panel inside the fresh food section just above the top shelf. I am here to anser any more questions should you need answers, Thanks Sea Breeze
Posted on Dec 12, 2012
Dimensions for whirlpool GU1200XTLS2
DOOR AND PANEL PARTS Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/gu1200xtls2/1198/.../00001.html
DOOR AND PANEL PARTS diagram for model # GU1200XTLS2 Whirlpool-Parts Dishwasher-Parts (24). Full Size. Print ... Owners manual Part #: 8283509.
Whirlpool Dishwasher Model GU1200XTLS2 Parts from ..
Jan 03, 2016 | Whirlpool Dishwashers
I have space for a 64in.height,32 in. width,26 in. depth refrigerator. What size in cubic feet should I get?
Well, these measurements will limit the outside of the cabinet. The size of fridges almost always refers to the inside capacity. The relationship between the two varies a little from model to model. For instance if you get one with an ice maker, the inside capacity is less, but the outside is the same as the same fridge without ice.
You could buy for instance a Whirlpool 14 cu ft top mount freezer model, which is 63" h x 28" w x 26" d. The 18 cu ft is too big. Another possibility is the Frigidaire 14 cu ft.
Nov 13, 2015 | Refrigerators
My whirlpool refrigerator freezer section around the blower fan is frosting up I changed the defrost heater and it still the same model number wrf560seym00. What next to try.
You may have an air leak around the door seal or the ice chute door is stuck slightly open causing compressor to run all the time as moisture from outside fridge to collect on fan shroud and evaporator. Are you defrosting normally or temperature rising inside fridge?
Appliance 911 Sea Breeze
Sep 18, 2015 | Whirlpool Refrigerators
What is the size of my kenmore 253.77879506 top freezer fridge
This appears to have been sourced from A. B. Electrolux (Frigidaire) but Sears does not supply a capacity. The outside dimensions can help determine the capacity as most 18 cu. ft. units will be approx. 66" high while 21 cu. ft. models will be 68" high (or higher.)
Oct 22, 2014 | Kenmore Refrigerators
What are the dimensions of Whirlpool Fridge Model ET18GKXGW01?
You would be safe if you used the current dimensions for todays
18cf Top freezer ref. 28" w x 67.5" h x 31" d
You are right no published spec's left too old I guess?
May I suggest measuring the space allowed for the fridge?
Jul 27, 2014 | Refrigerators
Dec 12, 2012 | Whirlpool Refrigerators
Refrigerators Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
