Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Ice o matic 1406 makesice but dont drop get thicker then high pressure trip
3 Suggested Answers
  • 193 Answers
SOURCE: Ice machine not coming out of the harvest
look at harvest thermostat
Posted on Apr 24, 2010
  • 112 Answers
SOURCE: ICE-O-MATIC ICEU220HA2 bridge too thick. Is the
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU220 with R-404A should cut in at 45psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Posted on Jan 04, 2011
I have a ice-o-matic 400ha2 ice machine that is not making much ice and is to thick. the timer has been replaced,but no change
reduce the thickness thermostat that initiates the timer to minimum, then increase until good ice made.
Aug 29, 2014 | Kitchen Appliances - Others
To big of icebridge
The ice bridge thickness of this machine should not be over 3/16" check the harvest assist solenoid and plunger during harvest to make sure it is operating. also check freeze cycle controller you will see it has some dip switches with off and on above the switches with numbers to the side of them you can take some freeze time out by starting at the top and moving the switch to off then let it make a batch of ice to see if this made a difference. The less time the thinner the ice. Time added to the controller the thicker the ice.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Where is the low pressure control and why cant the timer be bad on the ice o matic ice machine
Low pressure switch is usually in the control box which has a cap tube that connects to the low side of the system the timer can be bad but all a timer does is add a few mins to the end of your cycle but if you not making any ice you may have another issue
Apr 04, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
MACHINE DOSENT HARVEST
be sure the thickness sensor is not turned out too far
Apr 03, 2014 | Ice O Matic Complete Units ICE0500HA
What is a good suction pressure for ice machine
Assuming it's R-404A refrigerant it will start up somewhere around 45-60 psi and drop to somewhere around 28-34 psi by the time it has built up a sheet of ice.
Oct 22, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Making ice but won't drop it, then the compressor stops working.It is a Ice-o-machine
You can try and adjust your thickness a bit thicker. If this does not help, your hot gas bypass is not working and the evaporator is not warming. You will need a technician.
Apr 21, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
ICE-O-MATIC ICEU220HA2 bridge too thick. Is the time delay relay the "finnish" relay that adjusts bridge thickness? If so, I'm not getting any change in thickness with time adjustment.If the time delay...
Apr 06, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
ray gallant
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
