Question about Maytag Neptune MDE6800 Electric Dryer
How to wire thermal block on a Maytag Dryer model MDE6800AYW?
bomark2002
  • 160 Answers
SOURCE: MayTag Neptune MDE6800AYW dryer drum making
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Posted on Jul 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: maytag dryer access to the thermal sw
moz-screenshot-4.pngThe thermal limit mounts beside the heater element chamber and is held to it by the same screw that holds down the element.
The kit comes with 2 limits one fer gas the other fer electwic.
Posted on Sep 03, 2009
Testimonial: "well my model must be older because it has a barrel heater in the back and the front comes off with four screws in the door area "
milten1
  • 1304 Answers
SOURCE: maytag dryer won't start
thermal fuse is the white platic fuse mounted to the exhaust about 6'' from the blower
easy to get to with a snub 1/4 '' drive
Posted on Oct 03, 2009
cooper0365
  • 347 Answers
SOURCE: Maytag dryer overheating
have u replace heating sensor
Posted on Oct 23, 2009
miket756
  • 2702 Answers
SOURCE: maytag mde6800ayw dryer.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Posted on Oct 31, 2009
Testimonial: "very helpful, thanks"
Maytag neptune mde6800ayw electric dryer
The tensioner pulley for the belt, oil it with 3 in 1 oil, NOT WD40, if it stops then you need to replace the pulley because it will come back :)
Jan 31, 2014 | Maytag Neptune MDE6800A Electric Dryer
Model 7600ayw won't start. the terminal block
Very likely whatever made the terminal block break caused the internal thermal fuse inside the dryer blow,causing the dryer to now not start. You can get to the thermal fuse which is not resettable and must be replaced by removing the front panel and find the thermal fuse in the housing where the blower wheel is...it will look smilar to this picture oldtech2332_108.jpgfor you exact model the part number is 306604 and the terminal block with should also be replaced is 400008 they could be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Maytag Dryers
Mde6800ayw dryer just stopped working
Have her turn the breaker off to the dryer,then back on.
If it is not a incoming power issue the part #21 in the diagram will need replacing.
The connecting vent will also have to be checked for obstruction of airflow.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174651
cut and paste this link and find the thermal fuse part #21.
Jul 25, 2010 | Maytag Neptune MDE6800 Electric Dryer
Out Maytag Neptune dryer, model # MDE6800AYW, has no heat coming out of the dryer. We checked the vent line and it is clean. Is their something else we can check?
Upon starting up the dryer you should hear a clicking noise. That clicking is from the spark ignitor that ignites the burner. If not heard replace the ignitor
Apr 06, 2010 | Dryers
I HAVE A MAYTAG NEPTUNE MODEL NUMBER MDE6800AYW
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 05, 2010 | Maytag Neptune MDE6800A Electric Dryer
Mde6800ayw - Dryer runs but does not heat.
no it is the heater element needs replacing on the out side of the drum. hope this helps
May 12, 2009 | Maytag Neptune MDE6800A Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune MDE6800 Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
