Question about FAIP 1500 PSI Electric Power Washer
Why won't the motor start?
The water will come out but the motor will not start
2010 Yamaha FX Crusier jet ski
sparks ? compressions 100psi or more ? water in fuel ? injecters clean ?
Jul 14, 2013 | Boating
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Hi my GW709 7.5 smartdrive excellence won't fill with water and won't agitate if I manually fill it , help me please
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Feb 12, 2013 | Washing Machines
My Jacuzzi Tub won't start
Try compressed air through the system,careful not to use too much pressure. Also you may use another water pump to push water through system and free up the motor. The easiest thing may be to get a new motor though.
Dec 10, 2012 | Home
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My 2003 lancer over heated and won't start now.
too late, but the answer is: when the water system loses enough water, there is a sensor in the water inlet that tells the computer that there is no water, then the computer will not allow the engine to start, I check it on a radiator change I had to make a lancer 2006, we wanted to move the car a few meters but did not start because the hoses were not installed and the block had no water, so we had to start pouring water with a garden hose to the water inlet of the block and in that way started the engine.
Sep 16, 2011 | 2003 Mitsubishi Lancer
Euro Pro X 1750 psi Pressure washer won't start. It's plugged in and water is attached. it was fine last time i used it.Now it makes a short noise like it wants to start, but doesn't.
Check the nozzle to see if is plugged. If water can" pass thru , it won't read a water pressure drop and turn on the pump motor.
Aug 26, 2011 | Garden
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Drove car thru water. Car died instantaly. water was knee deep. Pushed car out of water. will not turn over now.???
when you say it won`t turn over do you mean it tries to turn over with the starter or it won`t start.if you mean it won`t turn over then when it dries out a bit(water has drained from electrical components)try it again.if it still wont then its possible it may have sucked up water into the cylinder.pull the plugs and try to turn the motor over.if it does then this is the problem.if you mean it won`t start then let it dry still for water in a component may cause electrical issues when wet.just suggestions.
Apr 28, 2011 | 1997 Saturn SL
FAIP 1500 PSI Electric Power Washer Logo
155 people viewed this question
Top FAIP Garden Experts
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Mister Danger
Greg P
Greg P
Are you a FAIP Garden Expert? Answer questions, earn points and help others
