Question about American Standard Heating & Cooling
Error code 91 - American Standard Heating & Cooling
Sony camcorder xdcam pdw-700 error codes 91-225
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
Feb 22, 2017 | Sony Office Equipment & Supplies
What does it mean when my Frigidaire professional series dishwasher has an error code of 91 and the China/Crystal setting light is illuminated?
Rod, Try unplugging or turning off breaker for ten minutes to reset. If this does not fix, you may want a good Tech. have a look, diagnose and estimate repair.
Code E91 could be User Interface to Main Control Board communication error. Communication problem. Check the wiring between the Main Control Board and the User Interface Board. Wiring bad, correct wiring problem. Wiring good, replace the User Interface Board. If the problem is not corrected, replace the Main Control Board.
What Is Error Code 91 On Frigidaire Dishwasher Professional Series
http://www.manualsonline.com/support/frigidaire/dishwasher/error-code-91-5195801
http://forum.appliancepartspros.com/washer-repair/476079-error-code-91-a.html
http://www.elektro-ivicic.cz/data/user-content/soubory%20ke%20stazeni/Electrolux-chyby.pdf
Jul 14, 2016 | Frigidaire Dishwashers
Why is code 91 on screen?
About 1,080,000 results (0.79 seconds) Search Results
    Chevy Cruze error code 91 - Fixya
    www.fixya.com/cars/t18378173-chevy_cruze_error_code_91
    Jun 2, 2013 - Chevy Cruze error code 91 What is Error code 91? It appeared ... Ya i know that what is error code 91 it is that ur car key is not there & if shows error code35 then ur car remote key cell losing his power exchange with that cell & ur car is ok. Posted on ... SOURCE: chevrolet cruze 2.0 LT 163cv error. If im not ...
    Warning: Cruze Start/Stop button & Immobiliser Design Flaw ...
    gearheads.in > Forum > Indian Automotive Scene > Chevrolet > Cruze
    Apr 16, 2013 - 10 posts - ‎7 authors
    4kms later I realised that I had the Cruze key with me in my pocket ... If the key is outside the car and you try to start it, it throws a Code 91 Error ...
    Cruze error code ' Chevy Cruze Blog : Chevrolet Cruze Blog
    www.cruzeblog.com/cruze-error-code/
    Translate this page Mar 7, 2014 - Cruze Error Code Vehicle message 1 C
Feb 09, 2016 | Chevrolet Cruze Cars & Trucks
What does error code 90, 91 and 92.
if its a nsm jukebox the three error codes refer to title mech jam
Mar 02, 2014 | Audio Players & Recorders
ya i know that what is error code 91 it is that ur car key is not there & if shows error code 35 then ur car remote key cell losing his power exchange with that cell & ur car is ok
Jun 02, 2013 | Cars & Trucks
Cyber shot DSC-W561 error code E:91:01 - how can reset normal condition?
Download the service manual from elektotanya.com and find the complete explanation to the error codes. This is a service center job.
Nov 04, 2012 | Sony Cyber-Shot DSC-W560 Digital Camera
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
Mar 20, 2009 | Sony DSR-1500 Mini DV VCR
DSC W55 Error code E:91:01
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Heating & Cooling Logo
12 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
