Question about Heavy Duty Arrow Et501 Electric Staplenail Gun
Et501 broken help
Contacts to be transferred from Samsung Galaxy A3 to computer, screen broke so I cant move contacts to sim. Please help
If you are using a Google account for the phone just log in to your gmail account on the computer then look for contacts.
Nov 14, 2016 | Samsung Cell Phones
Runs but doesn't turn. Worm gear is not broken.
Something must be broken if the motor is turning and the planetary is not. It will be one of the following, we will start from the first point of contact with the armature
1) Worm gear broken (fuse gear) you say no teeth broken
2) Worm gear not broken but whole unbroken plastic part not gripping aluminium boss
3) Pin through worm gear broken or missing
4) Pin through centre (or bevel) gear broken or missing
5) Pin through small gear in planetary broken or missing
6) Pin through planetary hub centre shaft broken or missing
The most common ones in order of likelihood are, 1, 2, 3 and 6
Dec 29, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Valve leaks or stuck. how do I fix?
PS blaster has a product called air tool tune. Try cleaning it really good and then lube up. If it continues you can order a tune kit and disassemble and install the tune up kit
Oct 29, 2014 | DeVilbiss Excell ET501 12" Impact Wrench
How to remove broken bolts from power steering
you can use easyout.if there is room to drill middle of the broken bolt easy out will help you out
May 05, 2014 | 1997 Buick LeSabre
Driver side inside door opener will not work
Hi Paul, I'm glad to help!
Paul, I'm assuming your talking about when you pull the inside door handle it does nothing. The most likely problem found with this type of problem is broken parts. If you have the know-how here's what you can do. Remove the door panel. Move the handle while watching and see what is broken. Simply replace the piece that is broken. Weve found everything from the handle being broken where the rod attaches too. To something as simple as one of the plastic retainers that holds the rod in place being broken or came loose. You'll simply need to see what's broken on your and replace it. Hope this helps and have an awesome day Paul.
Feb 10, 2014 | 2004 Hyundai Santa Fe
How do you load staples in ET501? I pinch the back of the loader together but it won't pull out.
Try pinching it and pushing it down at the same time. If that doesn't work then there is likely a jam.
Jul 02, 2011 | Heavy Duty Arrow Et501 Electric...
Im going to buy a compressor ! What is the min scfm comp that will run this tool for small jobs on my car?
Hi and welcome to FixYa, I am Kelly.
Air Tool consumptions are based on 15 seconds per minute (25%) of tool use.
Usage rates refer to the total time that air is flowing through the tool. If your applications result in more extensive usage, calculate air tool requirements as
follows.
(25%) 15 seconds = rated scfm x 1
(50%) 30 seconds = rated scfm x 2
(75%) 45 seconds = rated scfm x 3
(100%) 60 seconds = rated scfm x 4
Your impact wrench is rated a 8 CFM Cubic Feet Per Minute Usage
SCFM is Standard Cubic Feet per Minute (pre-compressed air volume)
I would be more concerned that the plumbing from the compressor tank could support the 8 CFM required by the 1/2" Impact. Remember the Air compressor will recover the pressure loss regardless of size. The only problem your going to have for "small jobs" is if you use too small of an air line to supply the impact wrench you are not going to get the full torque that it will produce to the drive head. In other words... a 1/4" supply line or 1/4 fittings anywhere in the system just isn't going to cut it even at 120 PSI. If you have the patience... a 5 gallon tank compressor that has the output volume required should be all that you need. I have been a mechanic over 4 decades and rarely have to use a 1/2 in impact for very long. Examples of 1/2" vs 3/8" useage. Wheel nuts, crankshaft pulley center bolt, some starters, steering, suspension and rear end parts. Other than that a 3/8" Impact works great.
One other thing you can do if you have an Air-Peen portable tank (with added fittings) is to add that in line with your output hose when your using the impact wrench so that you have longer use times.
I know this does not answer your what SCFM compressor is required question but it will resolve your needs. I just can't see telling someone that is a "small jobs" user to buy a larger compressor when really all they need is more volume for a brief period of time. The re-plumbed 1/2 inch output / in-line Air-Peen tank is a much cheaper and reasonable work around and you can disconnect that tank when your not using the impact wrench.
Lastly... if your inpact wrench has a SMALL male air fitting everything above will be a waste of time. You have to get that volume into the tool without restriction so that the rool will work properly for you.
Thanks for choosing FixYa.
Kelly
Mar 09, 2011 | DeVilbiss Excell ET501 12" Impact Wrench
Broken wheel nut
Broken nut or broken stud,, more details please a pic and description would help us help you, also front or rear
Nov 15, 2010 | 2000 Honda Accord
Heavy Duty Arrow Et501  Electric Staplenail Gun Logo
51 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Tom Chichester
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
