Question about Black & Decker 4 1/2" Small Angle Grinder
High vibrations & pinion looseningin 4" angle grinder
Can you pls list ourt various key points to be investigated if a 4", that is, a 100mm angle grinder has high vibrations while working.
Secondly the pinion gets loosened. I used a lock nut above the pinion so that it arrests the movement of pinion upwards. But the nut again gets loosened.
Kindly help me out by stating what might be the suspect.
  • 2,176 Answers
Could be couple things the wheel is out of balance or out of round causing the vibration, the armature shaft could be bent causing this also the bearings could be bad. One last thing to look at is the fan on the armature to make sure not cracked or missing fins. Let me know the model and brand and I will look further
Posted on Jul 20, 2009
My Makita "GA9020 9"" Angle Grinder has started to vibrate really bad.there seems to be play in the spindal.its used for floor sanding.i was thinking maybe bottom bearing,but just guessing any ideas thanks
Vibrations and excessive play could be caused by one of two or both bearings in the gear housing or the spiral bevel gears. Armature bearings can cause vibrations but usually don't show up as play at the spindle. Also, if the vibration is really bad, you could have several fan blades broke off one side of the armature fan throwing off the balance.
Oct 09, 2013 | Makita "GA9020 9"" Angle Grinder- 15 AMP-...
I have a dewalt 28402 grinder. I have replaced the pinion but I don't know how to get the helical gear out of the case to replace it. Any thoughts? Thanks Chris
You can buy the pinion gear as a seperate part but not the ring gear. Dewalt only sells the ring gear as a part of the gear case assembly, PN 623586-00.
Oct 28, 2010 | Dewalt D28402K Heavy Duty 4 - 1/2" Small...
I have a Makita 100mm Disc grinder what attachments are available for this older tool...model M952
as its a grinder...there are not many attachments available....just your common grinding and cutting discs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 06, 2010 | Makita 9553NB 4" Angle Grinder
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
I need a parts list schematic
CLICK HERE or HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 10, 2010 | Metabo W23 180 Angle Grinder 7" 8,500 Rpm...
Ingersoll rand g2 angle grinder exploded parts diagram need to find part numbers for the bevel gear and bevel pinion gear
Follow this link: http://www.irtechpubs.com/ir_pdfs/Tools/Finishing%20-%20Surface%20Prep/Air%20Grinders/04581237_ed5.pdf
On page 5 of this publication you will find 2 sets of bevel gear and pinions. You need to know which model grinder you have in order to get the right set. The different models are G2E, G2A, and G2L. On page 4 you will see the diagram for the right angle. You may be able to match up by sight which one you have. If you have the A or L you need to know the rpms of your model to get the right set.
Sep 08, 2009 | Air Tools & Compressors
Ground Wire?
You don't. It's a double insulated tool.
Jun 12, 2009 | Black & Decker 4 1/2" Small Angle Grinder
Ryobi angle grinder broken locking nut
You should be ablt to find it at anylowes or home depot.If for some reason thet do not have one I would call the local industrial distributor like grainger or msc
Nov 13, 2008 | Saws
Grinders power question
Consider a high amp motor if you want enough power (torque) for heavy use without stalling or slowing
Aug 27, 2008 | Hitachi G10SR3 4" Angle Grinder 6 Amp
Black & Decker 4 1/2" Small Angle Grinder  Logo
180 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Frank Mangiapane
Level 1 Expert
Mike
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
