Question about RCA P52937 52" Rear Projection Television
A buzz nosie every time i plug in the t.v
T.V won't turn on is not getting power and there's just that buzzin noise since that started it hasn't worked
    Sergeant:
    Champion:
  • 346 Answers
COULD BE AN OLD ELECTROLYTIC CAPACITOR IN THE POWER SUPPLY
Posted on Apr 30, 2008
When shower is activated can hear buzzing noise.I removed shover head arm and use only unrestricted hose.Buzzin do not stop.Then entire valve was replaced but with new one and problem still exist.
It sounds like the washer on the integral stop my have come loose and is fluttering. Remove the handle and faceplate. You may see a screwdriver slot on either side of the main valve. Tighten one of the screwdriver stops all the way down and turn the water on. If you still get the buzzing, open that side and close the other one. Now turn the water on again. If the buzzing stops and you do this, then I was right. If after going through the steps you still have a buzzing I don't have a clue
Dec 10, 2015 | Moen Home
WHY IS THERE A BUZZIN NOISE IN RADIO ON MY hARLEY?
Shoot, forgot to mention, take a coat hanger (one coated with plastic so as not to cause spark). Tape the ends if you wish. Push that down the input tube once the hose is removed from below.
May 21, 2014 | Canon PowerShot S230 / IXUS 179 Digital...
Car won't start when i turn the key i hear a clicking nosie, dead battery or what?
do you hear a hising noise if you dont your fuel pump is shot but if you do check your spark plugs and wires..also have some one give you cables see what happens
Sep 09, 2011 | 1998 Saturn SL
Sounds like my front differential is going out or the pit gear
It sounds to me that either the gear dogs have broken off one of the slider gears or the gear teeth on a gear or two have sheared off. This means a total engine teardown to get to the problem gears.
Jul 23, 2010 | Honda GL 1800 Gold wing Deluxe Motorcycles
I have a HP w2338h monitor that goes blank
It is most likely a bad power supply... I have had aboit 4 diff monitors do this to me... most common is under rated capacitors in the internal power supply... some times there could be a black light going out witch causes higher current draw on the power supply ( witch can take out the caps, fusses, transformers ( caps and transformers when they get week and bad can cause the buzzing sound ( on some times with a radio near buy then the monitor is acting up with blanking out and buzzine the radio will pop and buzz as well witch is a sign that there is arching going on IE. caps and transformer are most common for that )))
hope this info helps
kc7wzl
Jun 23, 2010 | HP W2338H Monitor
How to determine weather it is the power steering pump, or hose?
power steering will make a buzz nosie and it will get worse when the steering wheel is turned. It usually is just low n power steering fluid. Check that first. The other is a belt squeal noise, worse when turning, which usually just requires tightening unless it's self tensioning syste. Or replace the belt. Need a better description of the nosie and results of fluid level check. Report back on findings.
Please rate as fixya if this resolves your problem.
Mar 05, 2009 | 1999 Pontiac Grand Am GT
Need Help
have you checked the fuel pump?
Jan 06, 2009 | 1992 Buick Century
STANTON SK-FIVE MIXER HOOK UP
are the gnds connected(earths) you get a buzzin noise if not earthed
May 15, 2008 | Stanton Sk2f DJ Scratch Mixer - Good...
High pitch buzzing and no picture
Your power supply, I mean the internal power suppy could be faulty, if you know how to deal with it, check it for abnormal oscillation, or get some help from someone who knows how to repair it.
Jan 28, 2008 | Sansui CVDV9000 9 in. TV/DVD Combo
Television problems
Have the speakers ever been played loudly? They may have been pushed passed their capacity, in which case, it may be time for a new tv.
Dec 16, 2007 | Televison & Video
RCA P52937 52" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
