Question about U-Line ?chelon 2175RB-00
How to Bypass the temp sensor - U-Line ?chelon 2175RB-00
Heater will shut down within minutes of igniting and say heater cool down mode
what does water temp show if over 104 replace temp sensor make sure filters are clean if you have a heater bypass make sure it is at least half way closed or possible manual bypass spring broken or if gas pressure too low heater is sooted up and overheating
Jan 03, 2016 | Jandy Lite 2 Natural Gas Pilot Light...
What are the probable causes of DTCs P0030, P0039, P0074, and P0098?
code p 0030 refers to heated oxygen sensor (HO2S) 1 bank 1 -heater control-circuit malfunction
code p 0039 refers to turbo/super charger bypass valve , control circuit --range /performance problem===causes --wiring--- bypass valve
code p 74 refers to outside air temperature sensor--circuit intermittent===causes ---wiring---poor connection---out side air temp sensor---ECM
code p 0098 refers to intake air temp (IAT) sensor 2 --circuit high input===causes --wiring short to positive ---IAT sensor---ECM
Nov 23, 2015 | 1994 Cadillac DeVille
FL1 on a Jandy Lite2 LJ250N even after replacing the temp sensor.....is there any way to bypass the sensor to see if there is a different problem?
if you replaced the temp sensor and it still does that check to see if you didnt short the wires if all ok sounds like pcb board
Aug 10, 2014 | Jandy Pool & Spa
Why does my Pentair master temp reads 225 degrees
bad temp sensor or hooked up backwards or bypass stuck open
May 03, 2014 | Sta Rite Sr200lp Max E Therm Pool & Spa...
2002 pontiac aztek overheating problems
If you bypass the temp sensor for the computer and the fan does not come on, and you know the fan and the relay works, that leaves the computer. The computer grounds the fan relay with a signal from the temp sensor.
Sep 14, 2012 | 2002 Pontiac Aztek
Where is the temp gage sensor location 2001 merk cougar
The temperature gauge relies on readings from the Engine Coolant Temp (ECT) Sensor.
The ECT sensor is usually located on (or near) the thermostat/coolant housing.
Refer to component No. 8 (2.0L Engine):
Refer to component No. 9 (2.5L Engine) locate under bypass tube:
Hope this helps.
Cheers,
Aug 27, 2011 | 2001 Mercury Cougar
What is code 23 for pontiac grand am is it vacume leak
Wow these are hard to find!!
Diagnostic codes for 1987 Pontiac
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Vacuum Control
33 Mass Air Flow Sensor (MAF) (GM/SEC High)
34 Mass Air Flow Sensor (MAF) (GM/SEC Low)
41 Cam Sensor Circuit
42 C3-I EST or Bypass Circuit Failure
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM Error
52 CALPAK Error
55 ECM Error
If you have your owners manual they should be in there. I couldn't find one online but did find this.
Future reference
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-28.htm?once=true&
I hope these helped you
Nov 26, 2010 | 1987 Pontiac Grand Am
Car keeps dying
Trouble Code 33 and 34 are the MAF/MAP Sensor Circuit. It sounds like you've replaced that sensor already. Did you also have the code 34 before putting in the new sensor?
Or did this code start after it's replacement? Any other codes appearing?
Troubleshooting it would depend if it has the Speed Density Update. The dealer should be able to provide that info.
Here's your fault code list:
13 oxygen sensor circuit 14 coolant temp sensor circuit (high temp) 15 coolant temp sensor circuit (low temp) 21 throttle position sensor (TPS) circuit (high signal) 22 throttle position sensor (TPS) circuit (low signal) 23 manifold air temp (MAT) circuit (low temp) 24 vehicle speed sensor (VSS) circuit 25 manifold air temp (MAT) circuit (high signal) 31 wastegate solenoid electrical circuit 32 exhaust gas recirculation (EGR) circuit 33 mass air flow (MAF) circuit (gm/sec high) 34 mass air flow (MAF) circuit (gm/sec low) 41 cam sensor circuit 42 C3I EST or bypass circuit failure 43 electronic spark control (ESC) circuit 44 oxygen sensor circuit (lean exhaust) 45 oxygen sensor circuit (rich exhaust) 51 PROM error 52 calpak error 55 ECM error
Aug 07, 2008 | 1989 Buick Regal
U-Line ?chelon 2175RB-00 Logo
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
