Question about Home
My oversized clock was dropped. Nothing seemed to be broken, but it would run and then stop.Thought we needed to replace the battery compartment.Wrong! I think it's something to do with the hands. How do I adjust the hands? Thanks!
5 Suggested Answers
SOURCE: My Lacrosse radio controlled clock (IECLR6) has
Mine does the same thing. I contacted the manufacturer and they told me there's nothing I can do to fix it. They suggested I return it if it's under warranty (which it isn't). With no warranty they said there is no way to repair it.
Posted on Dec 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: We have an Atomic Lacrosse
Directions:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
support@lacrossetechnology.com (warranty work)
sales@lacrossetechnology.com (information on other products)
web: www.lacrossetechnology.com
Posted on Jan 19, 2011
SOURCE: Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at skyscaninfo.com
Posted on May 29, 2011
gopakumarg43
  • 75289 Answers
SOURCE: Second hand has stopped working.
Hello
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Posted on Jul 03, 2011
No hydraulics working yet everything was fine the night before
My thought also. Does the engine run but hydraulics not work? If engine has a starter, check the battery and battery connections.
Need more information in detail.
Nov 27, 2014 | Garden
My Vespa ET4 Clock Stopped Working, How do I fix it?
The battery that powers your scoot has nothing to do with your clock battery. The clock runs on a small round battery directly under the clock. I had to have my shop do it because you have to open up the entire top cover. Cheap fix, and having the date show is great for us oldsters!
Jun 15, 2012 | Vespa ET4 125 Motorcycles
Accidentally dropped my clock now none of the electronics seem to work. radio still plays.
Hi, a lot of things inside might have shifted. You can loose it and see which is not at the right position and adjust or check which is broken that will need to be replaced.
Take care.
May 18, 2010 | Philips AJ3935 Clock Radio
My keyless entry stopped working on my 2005 Jeep Liberty. Replaced the battery on the key and tried my backup key nothing happens.
YOU WILL PROBABLY NEED TO HAVE THE REMOTES REPROGRAMED TO YOUR JEEP IT SOUNDS LIKE THEY LOST THEIR PROGRAM,LOTS OF THINGS CAN CAUSR THAT TO HAPPEN ,LIKE HAVING THEM TO CLOSE TO A MAGNET LIKE LAYING YOUR KEYS ON THE HOME STEREO SPEAKER,OR CLOCK RADIO,DROPPING THEM SEVERAL TIMES, ETC,& ITS POSSIBLE THEY WILL NEED TO BE REDONE AFTER THE BATTERY REPLACEMENT.
Dec 05, 2009 | 2005 Jeep Liberty
Cybershot will not store clock settings
Hi!
The internal battery is bad. It has to be replaced. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 06, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
hi there...i have the same problem..did u find any solution for the very same..
get back to me on
anand_doshi@in.com
Jul 06, 2009 | JVC GC-S1 Digital Camera
I was playing a cd and it just stopped. The lights went out, no power, no nothing. Seems to be dead...
There's a line fuse for these sets inside the radio on a printed circuit board. NOTE: for your safety, disconnect the radio from its power source before you open the case and poke around inside. The best way to check the fuse is with an ohm meter, but you can probably check it visually using a strong flashlight. There should be a wire filament running the length of the fuse. If it's intact, so is the fuse. If it's broken or not visible at all, the fuse is "blown" and needs to be replaced. If the fuse checks out ok, the power transformer is likely bad -- a problem that these sets are notorious for. Bose will charge you $100 for the transformer repair (unless the set is still under warranty), and having it done is strictly a matter of personal choice. My choice would be to sell the Bose on eBay as a "tech special" and pick up one of the newer HD radios. They offer much better sound at a much lower price.
May 11, 2009 | Bose Wave Radio
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
