Question about Hayward Industrial Products Hayward EcoStar Variable Speed Pump SP3400VSP
Drive error on Hayward variable speed pump
Pump started then suddenly stopped. Impeller issue is my guess. can we replace ourselves
Hayward 1hp super pump-self priming -rebuilt won't run
something is binding take apart and try again
Jul 30, 2013 | Hayward Pool & Spa
Navigator and variable speed pumps?
check to see if not close off some of the returns till it will if suction device close off main drain or other skimmer
Sep 03, 2012 | Hayward Navigator Pool Cleaner
My Hayward pump was very noisy but now trips the breaker. I can turn the impeller from the rear pretty easily.
Hayward is synonymous with junk. Let me guess. It's been in service for about two or so years when the noise started. Eventually the motor will burn out. I've gone through two motors and a diffuser on my Hayward pump. It's already making noise again.
Jul 16, 2012 | Hayward Pool Products Hayward Power Flo LX...
If my hayward pool vac (AquaBug) is always connected when the pump is on (4 hrs/day), do I need (will I benefit) from a variable speed or 2-speed motor? Or, will I do fine just by downsizing from 1.5 HP to...
Probably go for the 2 speed, manufacturers often embellish on the hp ratings of pumps, you will definitely see more energy savings from a 2 speed. Just stay away from hayward, easy to work on for service tech's for break alot. Go with Pentair or Jandy they are worth the money.
Nov 21, 2010 | Hayward Pool & Spa
Powerflo matrix pump is humming not pumping
I think you have a start/run capacitor issue or your impeller has spun its center out. Check the impeller first. If the impeller is intact, take your motor to your full service pool professional for repair.
Aug 01, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
This June, I had to replace my strainer housing on my Hayward Power-Flo Matrix pump. It cracked in cold weather before I remembered to remove it. On installing a replacement, I noticed that the pump showed...
One or more of a couple issues is at play here. First would be the seal replacement. Even if you used the correct seal if you touched the surfaces or failed to install it properly it can and will leak. Second, inspect the housing around the seal fit and the stem of the impeller for cracks. A hairline crack is enough when placed under pump operating pressure to allow a leak. Somewhere in there is your solution.
John
Jul 17, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward pump hums only
Replace your start capacitor ... before you do that ... is the hummng the motor withoug the impeller? Your impeller may be broken.
Jun 25, 2010 | Hayward Pool Products Hayward Power Flo LX...
My pump is 3 years old. I replaced the shaft seal assembly and now the motor is making a strange sound (much quieter than normal) and shutting off every minute or so. There is no pressure on the filter and...
Sounds like the motor is not turning. Check your impeller and motor to see if it spins freely by hand.
If not then you either have something stuck in the pump or the bearings are bad. If it is freely spinning, check your start capacitor
Apr 16, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Pump wont run
does it turn freely if not check pump impeller for debris or damage repair or replace if necessary--if good- check motor bearings if not turning may need to be lubed or motor replaced check amp draw if spiked or nothing than possible open winding and may need replacement
Apr 08, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Hayward Industrial Products Hayward EcoStar Variable Speed Pump SP3400VSP Logo
62 people viewed this question
Top Hayward Industrial Products Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Hayward Industrial Products Pool and Spa Expert? Answer questions, earn points and help others
