Question about Aquacal HeatWave
What does the code HP5 mean where the tempature read out is
Service Code F-3
The error code's F3&F4 are codes that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F3 error code means that the sensor is shorted so if it indeed is shorted the meter reading will show ZERO ohms resistiance instead of the 1060-1100 of a good one.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If on either the F3/F4 error code if at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
Nov 30, 2011 | Magic Chef Ovens
Stove beeps and has f2
The F2 error code means that the over overheated by at least 100 degrees above the tempature that was set at the time. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms
GENE
Oct 08, 2011 | Kitchen Ranges
I have a kenmore elite oven what does an error code F-3 mean
Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Oct 03, 2011 | Kenmore Ovens
Pontiac grd.prx.3.8l what does the code:p0117 means
ECT engine coolant tempature sensor low volatage reading . you need to replace it. It screws in to the intake manifold next to the thermostat housing
Dec 19, 2010 | Pontiac Grand Prix Cars & Trucks
Oven temp not correct
One thing you should know about a gas oven is that they do not keep a constant tempature like an electric oven does. So going by a tempature gauge in the oven can fool you. The way a gas oven works is by "average" tempature. In other words if you take the highest and lowest tempature readings and average them out you will get the actual tempature. For example let's say that you set the oven to 350. Well first it will take about 10 to 15 minutes for the oven to properly pre-heat. Once it is preheated you can listen to the gas burner and watch a tempature gauge(flook meter is best). When the gas burner shuts off the oven tempature will continue to rise. When the oven tempature stops rising then you will take that reading. Then wait for the oven burner to come back on again and watch the tempature gauge. When the tempature gets to it's lowest point and stops then take that reading. Do this several times and then take all the tempature readings and add them together then divide that number by the number of readings you took and that will give you the actual tempature. Within 5 degrees is great but anything over 10 degrees can affect your cooking. This will give you an idea if your oven is out of calibration or not.
There is a calibration procedure. The instuctions are located in the owners manual and can be found here http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Just go to the "Thermostat Adjustment" section for the proper calibration procedure.
Jul 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
Wolf wall oven error message: RTD Open
RTD is resistence tempature detector. The oven is telling you that the tempature probe circuit is open. The temapture probe may have been damaged due to the self-cleaning cycle or it could just be the wiring harness is loose. You will need to remove the tempature probe and test it with a ohm meter. The average reading should be aroun 1200 ohms at room tempature. If it is testing open or the ohm reading is way off then you will need to replace the tempature probe. If it is testing good then it could be aproblem with the control board.
Dec 19, 2009 | Ovens
Aquacal HeatWave Logo
77 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
