Question about Dell Inspiron B120 Notebook
Dell inspiron b120 laptop won't power up
I've got a dell inspiron b120 laptop. It will not run on AC power. I know the battery is getting bad, and I'm sure it's dead now, but it won't even boot up with AC power. I checked the voltage on the adapter and it is correct. If the battery is in the laptop when I plug it in, the battery light blinks twice and that's it. The connection is good on the laptop. I've tried the hard reset, nothing. The green lights are the only signs of life, no fans, drive, nothing. I'd really appreciate the help. Thanx
  • ericcvitale Jun 23, 2009
    Are you sure? I just talked to dell and they told me you can take out the battery and it would still run on AC power. Are they steering me wrong?
    Sergeant:
  • 199 Answers
I dont know why dell did this but you have to have battery to run your laptop. the ac coard charges the battery which runs the computer. I really know why but i dont like the configuration. it is so the power is clean to your computer and so the can have less parts in the laptop you need to get a new battery
Posted on Jun 23, 2009
  • Richard Klein
    Richard Klein Aug 20, 2014
    My Inspiron B120 runs *only* with the battery removed. This is apparently a sign of a dead battery. I'm going to try buying a new battery, but it certainly runs with no battery installed, in any case.
Replaced DC power jack on Dell Inspiron B120. When I turn on the computer the 1st green light stays on steady the 2nd and 3rd blink occasionally but the screen is black. Any suggestions will be...
There could be many reasons for your problem from shorting something out while the motherboard was exposed to over heating the area at the power jack. My first and simplest suggestion would be to remove, and re-seat the memory modules. Are you sure you have good solder contacts on the jack you replaced?
Apr 30, 2011 | Amstron Dell Inspiron B120 Laptop AC Power...
Of the 4 display lights at left front of the keyboard of my Dell Inspiron B120, the third light from the left is frequently flashing orange (the other lights are green). Laptop seems to be functioning...
does the battery still work? that light i think is the battery light. i have a latitude d800 that has a bad battery and the battery light does the same thing
Apr 12, 2010 | Dell Inspiron B120 Notebook
My dell inspiron B120 will not turn on! What
hi there, there are many things that could be wrong here. First, make sure that the battery is plugged in with the power cord. If that doesn't work, it may be that the computer isn't reading that the power button is being pushed. If you know a little bit about computers and how to disassemble them and put them back together, take apart the top of the computer where the power button is, carefully disconnect the wires and look to see that the power button is not damaged. If it is, then you need to bring it to a computer repair shop for them to fix it. If not, then it is something to do with the connection between the power cord and battery not sending power to the system.
Feb 15, 2010 | Dell Inspiron B120 Notebook
My dell ispiron b120 turn on but when I but the battery the power goes from the power supply striaght to the battery and the battery won't charge. Any one knows how I can get the battery to charge?
It could be and issue with the Battery if the Battery is too old. Please remove the Battery from the system and check if the system works fine using only the adaptor. Also press the button located on the Battery and check for the LEDs on the Battery. If all lights blink, then the Battery is fine. Otherwise, it needs to be replaced.
Oct 19, 2009 | Dell Inspiron B120 Notebook
How to format the hard drive of a laptop without a battery
It should run with the bad battery in if AC power is connected. Then just run the restore cd. Good Luck
Jul 29, 2009 | Dell Inspiron B120 B130 1300 / Latitude...
Dell Inspiron B120 won't power on
Hi
I would check the RAM in the laptop and see if it is not seated properly. You should have 2 areas that hold #1 RAM Chip
One under the keyboard and one on the bottom. I had a Dell Latitude D620 and the ram was not seated properly and I received the same error.
I hope this helps
/Shawn
Jun 16, 2009 | Dell Inspiron B120 Notebook
Dell Inspiron B120 Notebook Logo
684 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
