Question about iPhone Apps
My ipad is frozen, wont power off. how do you reboot?
Stuck with a message and won't let me choose an option or exit out
    Champion:
  • 329 Answers
It will eventually power off when the Battery gets to low. To reboot, just press the power on button until the apple logo appears. If the battery is to low, that won't happen until you charge it back up. Good luck.
Posted on Dec 21, 2014
2 Suggested Answers
  • 52 Answers
SOURCE: Hi, My NPR app for my
I would reccomend reinstalling the NPR app on your iPad. Connect the iPad to your computer and deselect the app to uninstall. Resync the device and allow the NPR app to be removed. Then disconnect and reconnect the iPad and relect the NPR app and resync.
If this fails and the iPad still freezes, try restoring the iPad with iTunes. You can use a backup of the iPad to restore once the software is installed and all your apps and data will be restored. Only try this if the first solution does not work.
Posted on Apr 17, 2011
How to reboot an iPad, a video clip is stuck on running
Rebooting is easy. It is called a hard reboot. Just hold both buttons down until you see a red slider, and then slide it to shut down. It will restart, and you will see the Apple logo.
Oct 30, 2014 | Apple iPad 64 GB WiFi
My Coby Kyros mid 7048 is frozen on android? How do you fix that problem?
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 02, 2014 | Coby Kyros 7" Touchscreen Tablet
My IPad Settings site is stuck or frozen
Are you able to do a hard reset (power it off and back on again)? This may reset the issue.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Apple iPad 2 16 wifi has a frozen message on the screen and I cant use it. Message says ''Not enough storage" with options to 'close' or 'settings' but neither responds.
Hold down the power/sleep and the home buttons until you see a white Apple logo in the center of the screen and then releases both buttons. If it allows you to operate the iPad at this point, go right to work deleting apps to free up some space!
Jan 08, 2014 | Apple Ipad 2 16gb Wifi 3g Verizon Tablet...
My nexus 7 tablet wont leave the start up screen. I tried a hard reboot but it gets stuck on that screen
see the steps and fix it. God bless you
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPad will erase everything on it, so make sure everything on the iPad is stored elsewhere prior to restoring. To restore, connect your iPad to a computer with the latest version of iTunes installed. When your iPad appears under the devices menu, click the restore option under the summary tab. If you haven't backed up your data already, choose the back up option from the pop up window. Click the restore button to restore your Touch to factory spec.
Bad logic board
If attempting to restore the iPad and diagnosing does not fix the problem, the issue is probably the logic board.
Nov 03, 2013 | Televison & Video
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Jul 16, 2012 | Apple iPad Tablets & eReaders
iPhone Apps Logo
521 people viewed this question
Top Apps Experts
ray gallant
Are you an App Expert? Answer questions, earn points and help others
