Question about Ministry Of Sound MOSMP036 MP3 Player
My mp3 turns bk on when i turn it off whats rong
How do i download new software to my sylvania synet7wic-bk-z
need more info what operating system model of laptop/desktop make etc...
Feb 24, 2013 | Sylvania Synet7wic-bk-z2 Netbook
2008 flhr wiring skematic
Front or rear signals and brake??
Here is rear lighting for a start. Post a comment if you need front.
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
Nov 24, 2011 | 2008 Harley Davidson FLHR Road king
New head job radiator thermostat water pump computer and still running hot
WELL SOMTIMES YOU WILL GET WATER PUMPS THAT TURNE THE RONG WAY BUT YOU DID NOT SAY FAN CLUTCH COULD BE BAD THIS WILL COUSE OVER HEATING IF YOU NEED TO NO HOW TO TEST LET ME KNOW BUT IF YOU THINK YOU HAVE FLOW ISUSES YOU CAN GO TO ACE OR SOMTHING LIKE THAT BUY CLEAR HOSE SO YOU CAN WATCH FLOW OR YOU OR THE HEAD GASKETS CAN BE ON RONG OR RONG YEAR. HOPE THIS HELPS
Aug 07, 2009 | 2001 Ford Ranger Regular Cab
My mp3 will not turn on
hey is battery recharged if it is then trying holding button down for about a min if it doesnt turn on its probably a power problem in the circetry < ------ spelled rong
Jan 11, 2009 | Philips GOGEAR SA6045 MP3 Player
My samsung YP-K3 MP3 Player problem
on the bk is a small reset button try that 1st :)
faling that maybe a firmwire issue , try updating it or rolling it bk
Aug 22, 2008 | Samsung YP-K3 MP3 Player
Sansa e 200
Hello i have that same ecxat one maybe i can help u with it..wht is rong?
Feb 24, 2008 | SanDisk Sansa e200 MP3 Player
Radio
Check the TS guide at the end of the manual for info on the light settings:
Here is the link to the manual for the Samsung YP-F1X:
http://downloadcenter.samsung.com/content/UM/200504/20050412101655781_YP-F1-EngELS-bk.pdf
Oct 12, 2007 | Samsung Yepp YP-F1X MP3 Player
Refreshing data base
It refreshes the database to build the menu for you to navigate.
Your device may have corrupt data in it and therefore takes longer than normal to build the library.
You can format the device to remove everything, and then re-transfer them to see if that helps.
To format in My Computer>Device Name (e250)>right Click and select format.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa e250 MP3 Player
Files
you are probebly in the rong mode
Jan 27, 2007 | SanDisk Sansa m230 MP3 Player
Ministry Of Sound MOSMP036 MP3 Player Logo
14 people viewed this question
Top Ministry Of Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Ministry Of Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
