Question about LG LHT764 Theater System
Why door will not open on 5-DVD home theater system?
When pressing open on remote or unit, unit goes through process of checking each disk and then gives "disk error" code and tray does not open. Can pry it open during that process, but afraid will break it.
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
SOURCE: I have ATT U-Verse and
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Posted on May 03, 2009
  • 5 Answers
SOURCE: I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Posted on Jan 04, 2010
SOURCE: DISC ERROR MESSAGE
Usually it helps a lot if you take off the upper case of the DVD player (7 screws) and search for the lens of the DVD/CD. Clean it with alcohol or terpentine or something like that and it will probably work afterwords. Good luck.
Posted on Jun 26, 2010
SOURCE: How to break the region codes on an LG HT503SH
How to break region code on an LG HT503SH
Posted on Jul 18, 2010
I have a Samsung HTC 550 home theatre system. It's set to region one and I've tried everything to make it region free to no avail. I want to watch a region 2 DVD. Can you help??
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote. (if your player is already set to region 2)
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Turn off power from remote.
11. Turn power back on with remote.
Player is now Region Free.
or
Turn on with remote control without disc.
When message "No disk" appears, press on the remote,
ENTER,
8,4,2,6,9
ENTER,
If hack work after the second ENTER player will power off automatic.
When power on again this was region free, I can confirm now read region 1, 2 and 4.
Sep 08, 2016 | Samsung HTC-550 DVD Home Theater System
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Audio Players & Recorders
Tip
Follow these steps:
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
I am looking for an unlock code for a Samsung HT TZ122 Home Theatre System to allow me to view DVDs from various regions
1: Turn DVD player on, with NO DVD in the tray.
2: Press Repeat on remote control (bottom right key)
3: Enter 76884
4: Press 9
5: Open tray, close tray
6: Turn off DVD player, turn it back on.
Mar 11, 2011 | Samsung HT-Z210T Theater System
When eject is pressed, display says locked!
cant open or close dvd player.says locked.can use remote to play etc but cant open to change dvd
Mar 08, 2011 | Panasonic SC-BT200 Home Theater Systems....
Wanting a code to make my dvd player region free
1. turn de dvd unit on
2. open the dvd disk player and leave open
3. Pres 0 4 times
4. the region menu appears
5. change region
6. press pause to save and end
7 you are region free
Dec 26, 2010 | LG HT503SH DVDDivX USBHDMI 51 51 system...
RCA RTD315 Theater System The DVD Player recently
My identical system has exactly the same problem as the one described by dipaola, above. When I insert a DVD, the DVD carriage pops back open after a few seconds. In fact, mine won't stay closed even without a DVD in it, as long as the system is set to play a DVD. I'd like an answer to the big Q - Is there anything I can do about this, or should I just find another DVD player to hook into the system?
Nov 05, 2010 | RCA RTD315 Theater System
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Aug 08, 2008 | Philips MCD288/37 DVD Micro Theater System...
Disk drawer is locked
You have to reset the unit: While stopped, press and hold [ ] on the unit and [S10/ENTER] on the remote control for about 3 seconds until ?Initialized? disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Sep 23, 2007 | Panasonic SC-HT95 System
LG LHT764 Theater System Logo
32 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
