Question about Acer Aspire™ T180 PC Desktop
Acer aspire t180 cd tray wont open - Acer Aspire™ T180 PC Desktop
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 906 Answers
In case you're not able to eject the disc using the eject button or you can try right clicking on the CD drive under 'My Computer' and clicking on eject.
If that fails as well, you can try to eject the disc by pushing a straightened paper clip or a pin into the tiny hole on front of the CD drive. You should be able to eject it using the last method.
GuruAid
Posted on May 14, 2014
    Problem Solver:
  • 6 Answers
It could be a few things but does not sound software related. 1.) The drive is bad (happens more often than you would think). 2.) No power to the cd drive (less likely)-The power cable attached to the cd drive has come loose or fallen off. You will need to open up the computer case to check. 2.) A cd is stuck in it (even more less likey)There is usually a tiny hole on the front of the cd drive that you can fit the end of a paper clip into. Push the paper clip in and it should force the cd tray to open. You will need to push the tray closed with your hand. Considering you can buy a new CD Drive for about $40 now, and the fact that more than likely the drive is bad, I would go out to Best Buy and get a new drive, and replace the one you have. If for some reason that does not work, you should be able to return the new drive to the store.
Posted on May 12, 2014
ComputerDave
  • 128 Answers
SOURCE: how do you reset Acer Aspire T180-GB7Z PC
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Posted on Feb 02, 2008
SOURCE: i have bought the acer aspire t180 ro1-b4
No driver works! Not from Acer and not from Realtek!
So stop saying that one should install these drivers. THEY DONT WORK! TRY IT YOURSELF!
Posted on Apr 20, 2008
pagebor
  • 2785 Answers
SOURCE: acer aspire t180
plz check the hard disk and ram
Posted on Jul 21, 2008
  • 6 Answers
SOURCE: opening side panel of acer aspire t180
You have done half the work toward the solution by removing the thumbscrews. The other half involves sliding a spring-loaded lever above the lower thumbscrew toward the bottom of the case. While the lever is slid toward the case bottom, push on the side panel in the same direction as the screws, i.e. toward the rear of the case. The side panel should slide just slightly, allowing you to then lift it off to access the inside. Note that when replacing the side panel, follow the above steps in reverse order.
When replacing the side panel, note that if the panel is not correctly replaced, the thumbscrews will not be able to be installed as the lock lever will not be set properly.
Posted on May 28, 2009
SOURCE: Does Acer Aspire T180 support Windows 7?
i have an acer t180 which has 1gb ram and amd athlon 64x2 processon which gives me 2.01 ghz speed, i'v installed windows 7 ultimate converting from xp and everything seems to be running fine, there are netbooks etc which have low ram and processor speed but they still are sold by big companies with windows 7 installed
Posted on Oct 27, 2010
CD tray wont open! how can i open it?
There is a small hole on the front of the drive. just push a straightened paperclip into the hole and it will pop open.
Mar 20, 2012 | Acer Aspire X1200-B1601A PC Desktop
I have a disc jammed in the disc drive of my acer aspire 1800. How do I remove it
Normally there is a manual eject hole near the disk tray. Use a paperclip straightened out to eject the tray
Aug 07, 2011 | Acer Aspire™ T180 PC Desktop
How do i factory reset acer aspire t180 thank you
hi
if you mean about mainboard setting
go to bios and set as Default
if you mean your program, it needs to have recovery cd's
if you have put it in cd or dvd rom and restart your pc
May 30, 2010 | Acer Aspire T180 PC Desktop
Inernet drivers wont install
Un install them at once from device manager at modem option then follow the complete procedure to reintall them
Aug 19, 2009 | Acer Aspire™ T180 PC Desktop
CD's,such as games won't open
Does your screen get squiggly while doing other things? It sounds if you have a problem with your monitor or cable or the video card.
Jun 11, 2009 | Acer Aspire™ T180 PC Desktop
My pc is rejecting all cd/dvd's. It was working perfectly until two days ago
Well! Beggars *CAN* be choosers!
Get a laser-cleaning CD and run that through the drive.
If you can't (or are too cheap) to get one of those, try leaving the drive-tray open overnight to see if it's just a condensation problem.
Jan 29, 2009 | Acer Aspire™ T180 PC Desktop
Lack of sound
your model number is Aspire T180 and and you don't have any sound output.....
So, i suggest you that please check your sound card by right click on the My Computer and select the properties option then select the hardware option & see you have any sound device or not ... If you have sound device So please insert the Aspire T180 Driver CD into CD-ROM Device & install the Sound Driver & then restart your computer & your problem has solve...
Nov 01, 2008 | Acer Aspire™ T180 PC Desktop
T 180 desktop acer
Click on following link for audio driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-Audio-Driver-Download-37473.html
Click on following link for Ethernet driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-LAN-Driver-Download-37475.html
Regards,
Sandeep
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
