Question about Sharp AL2050CS Dig Laser C/P/2 20CPM 20PPM 600DPI Duplex Copy Print All-In-One Printer
How do you reset h4 code on sharp al2050 copier
Need reset sequence
  • 35 Answers
C interupt 0 interupt 14 start
Posted on Jun 23, 2009
Mon copieur affiche un code d'erreur h4
H4 = abnormally low heat temperature detected.
This can be caused by the following
Blown Heat Lamp
Blown Thermostat
Sometimes the code will be shown if a paper jam has got stuck inside the heat unit, blocking the sensor.
try resetting the code with the following sequence:
Press: Clear, Density Select, Clear, Density Select, 14, Copy Button.
Hopefully the machine will reset. If not, it may be possible to reset a blown thermostat by pressing the button on the back (it pops out if it detects overheating). This should really only be carried out by an engineer.
Hope this helps
Feb 09, 2011 | Sharp AL-1000 Copier
Tip
Sharp AL2020 AL2040 AL2060 AL2080 H4 H-4 code reset procedure
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:<br /> Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys) <br />Press "C" then the "Auto" key (exposure mode) then the "C" key then the "Auto" key again.<br />So in other words C, Auto, C, Auto<br />If done correctly the display should go blank.<br />Then key in 14 as if you were going to make 14 copies.<br />Now press the "print" button<br />The machine should automatically shut down and restart with the H4 code being gone.<br /> If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced. <br /> Works on Sharp AL series 2020 2040 2060 and 2080<br /> Good Luck and Thank You for using Fixya.<br />
on Dec 22, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
I have a Sharp Al 1566 Photocopier,Printer,Scanner and it has encountered a problem which is SYSTEM ERROR (H4-00) so how can I fix the problem?
H4-00 = Low heat roller temperature detection. This is usually caused by either a blown heat lamp or a blown thermal fuse.
Sometimes the error can show up for no particular reason. Try resetting using the following sequence:
#,*,C,* (hash, star, clear, star) then enter '14' and then press the start button.
The machine will reboot. If the code comes back you'll need to check the lamp and fuse for continuity (having removed the fuser from the machine first!)
Hope this helps.
Feb 02, 2011 | Sharp AL-1655CS Copier
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
How do i reset eorr H4-00 for sharp AL-1566
Oct 02, 2010 | Sharp AL-1655CS Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Please Help
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Sharp Z-830
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Nov 21, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL2050CS Dig Laser C/P/2 20CPM 20PPM 600DPI Duplex Copy Print All-In-One Printer Logo
546 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
