Question about ViewSonic N3251w 32 in. LCD HDTV
How do i turn off the menu lock on a dell IN1920 monitor ?
My DELL LCD MONITOR E178FP is locked, when i press menu button, on screen it displays lock symbol
Zaheer khan,
To unlock the monitor controls and get rid of the lock you can press and hold the menu button in for 20 seconds. You can also try the information listed in the link below.
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 28, 2015 | Dell E178FP 17 inch LCD Monitor
Tip
Dell monitor Lock and Unlock instruction
'OSD Lock': Controls user access to adjustments. When 'Yes' (+) is selected, no user adjustments are allowed. All buttons are locked except the menu button.
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds.
May not be applied to ALL Dell.
http://support.dell.com/support/edocs/monitors/E153fpb/En/controls.htm
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
http://support.dell.com/support/edocs/monitors/SE198WFP/en/setup.htm#Using%20the%20OSD
http://support.dell.com/support/edocs/monitors/3008WFP/en/ug/operate.htm
on Apr 14, 2010 | Computers & Internet
Lock icon and menu keeps appearing
Anonymous,
To unlock the monitor controls and get rid of the Lock, press and hold the monitor Menu button for 20 seconds. You can also try this.http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L.
Feb 28, 2015 | Dell E171FP
Not able to access menu, monitor doesn't react to menu key
Page 39 of the user guide built in self test.
Often when turning the power on, holding the power button pressed for 5-10 seconds will reset the device.
Mar 28, 2014 | Dell U2711 27 inch LCD Monitor
I have a dell monitor and I keep getting this notice that control menu is blocked. how can I resolve this?
For the E771MM, press and hold the OK button on the monitor for 15+ to toggle off the OSD lock. Holding the button turns on the OSD lock as well. The OK button is the rightmost of the control buttons (excluding the power button). This is a useful feature if a small child will be near the monitor or if the monitor is being used for demonstrations.
The user's manual for the Dell E771MM is here: http://support.dell.com/support/edocs/monitors/e771mm/English/index.htm .
I hope this helps.
Jul 01, 2011 | Dell E771MM 17" CRT Monitor
Cn-ou4931-46633-52L-OHGU - monitor keeps showing
Here you go!
From Dell website:
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds. See more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 13, 2010 | Dell E173FP 17" LCD Monitor
A lock symbol appears
Hello. On this Dell flat panel the menu access appears to be locked, if the lock symbol you are referring to is from the monitor itself.
You should be able to lock or unlock the OSD by pushing and holding the Menu button for 15 seconds.
Oct 23, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
How do I exit my computer monitor's main menu?
Here is a website that explains the big blue lock on the Dell LCD monitor and how to deal with it..a little too long to write so just sending you the website. If you have any questions let me know..
Pls rate this solution
Apr 06, 2009 | Dell Computers & Internet
LCD Monitor will not switch input selections
NOTE: You can also lock or unlock the OSD by pushing and holding the Menu button for 15 seconds. In this mode All buttons will be locked including the "Menu" button. You can unlock by pushing and holding the Menu button for 15 seconds.
Reference:
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Oct 16, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
ViewSonic N3251w 32 in. LCD HDTV Logo
32 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
