Question about Vizio VP50 10A 50 in. Plasma TV
Vizio VP50hdtv10a problems The "TV" mode, I can only hear sound. All the channel are black and white dots all over The "DTV" mode was working and now is gone after we installed a new cable box today The "AV" mode has not image no sound at all. It's dead. However, I can still see/hear from "Component" and "RGB" modes. It's 2+ years old and out of any warrenty (from VIZIO and Costco). Somehow I am not so shocked that it breaks right when we are off the warrenty. I called VIZIO authorized dealship and they are asking $600+ flat rate for repair (regarding small or big problems) which is 2/3 of the price for getting a same brand new VIZIO tv in costco. I am not sure what should I do??? Please help!
  • 92 Answers
If you still have audio and video from component and RGB which means your sustainer boards (the boards on the two sides that powers up your screen) are working. All you have to do is replace the main board. you can buy parts at Vizparts.com, Vancebaldwin.com or shopjimmy.com. Make sure that you give them the correct model and serial number so they can send you the correct part.
Posted on Jul 08, 2009
Wow I have the exact same problem 50" plasma av inputs quit working. just under 3 years old, I already bought new cables HDMI and component for my wii. these inputs still work the we cables cost $25, wonder if the wii system has something to do with this? I have seen a few problems posted on the internet after people use there wii I am going to look into a new board good advise thank you..
Posted on Apr 26, 2010
I have the same problem.... my coax. AV1 and AV2 are not working, however Component 1 and 2, HDMI 1 and 2 all work fine ...for now.....grrrr....2 years for me as well.... I thinking that those three inputs are on the same board.... (coax, AV1, and AV2) I actually diagnosed the problem by troubleshooting the AV inputs (trying to hook up my WII) then I thought to myself.....maybe the coaxial input is working...so I went and bought a RF Modulator...and found that the screen was scrambled....changed out the coax cable and still same result ...audio no prob...just bogus video.....
My solution:
now...if you can not afford any of the above..... you can try to buy a composite to component converter (or cable)..... or composite to HDMI ..something of that nature.....whatever you are trying to use ...convert it to the input type that you know is working....
Also one could buy an upconverting receiver and you may be able to upconvert all of you various formats all to one HDMI cable.
Posted on Dec 29, 2009
  • Fireeye1 Dec 29, 2009
    My solution:
    UPDATE: FOUND THE SOLUTION THAT FIXED MY PROBLEM!!!
    http://www.fixya.com/support/t1298692-vi...
    Problem Solver:
  • 6 Answers
If you have a voltmeter, take off the back and check the power outputs on the power supply module.
Posted on Aug 06, 2009
Turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv on & off but none of the other buttons work and the screen remain
tcon board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Nov 19, 2017 | Vizio VOJ370F 37 in. LCD TV
Some dtv channels missing on VIZIO
Have you tried doing the channel search? If that does not help replace the main board
Apr 12, 2014 | Vizio VL370M LCD TV
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
Suddenly no picture only a black screen.The tv has power the little vizio turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv...
Look through the ventilation slits at the back of the TV with the room lights out. If you do not see white light light bleeding through the back, you have a back light failure. It could be the inverter circuit which lights up the CCFL ( cold cathode fluorescent lamp ). You will need professional help to replace it and could cost you about 70 to 100 $ to fix.
Jul 06, 2011 | Vizio VOJ370F 37 in. LCD TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Vizio LCD DTV 32 inch. Model L32. I can't 'scan' for digital channels. When I go to DTV, then Menu and scroll right or left to "TV tuner setup' I get a blue screen and nothing else. No key on the...
Follow up on No DTV tuner after unplugging it a month for vacation. After I let it set plugged in for about 2-3 days it started working normally again and has been fine ever since. I hope this may help someone else. Genez 6-7-09
Mar 23, 2009 | Vizio L32 32 in. LCD HDTV
Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Feb 08, 2009 | Vizio VP50 10A 50 in. Plasma TV
Vizio VP50 10A 50 in. Plasma TV Logo
2,344 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
