Question about Brother XR-65t Mechanical Sewing Machine
What size needle for sewing vinal on brother xr 65
A size 16 needle seems to be peeling the thread back what is the problem
SOURCE: brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Posted on Dec 08, 2008
SOURCE: while sewing the bobbin case moves, wheel locks up, needle locks
Im not sure if this will help but thought I would pass it along. My Pfaff 6122 tells me to check bobbin for thread unrolling clockwise before you place it back in the machine. I had mine turned to un roll counter clockwise, this is wrong, the bobbin will fall out when you pull on the thread while you are holding it in your hand. You may just keep putting it in backwards. Hope this works for you. J.R.
Posted on Feb 05, 2009
  • 360 Answers
SOURCE: how to operate a Brother Compal DX
This -->link<-- is the Quick Set-up Guide for your machine.
This -->link<-- is the complete Owners Manual for you machine.
It sounds like a threading problem to me. it is covered in the Quick set-up and the Owners Manual
Hope this gets you sewing again
Thanks for using Fix Ya, please take the time to give this solution a Fix Ya rating.
clarkco
Posted on Feb 07, 2009
  • 9 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
Brother XR-36 stitch size (width) not locking
Have you tried a new needle and re-threaded the machine according to manual?
Mar 21, 2014 | Brother Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
The bobbin on my Brother Xr 34 sewing machine won't catch Please help
try changing the needle
try a different bobbin
try turning the bobbin the opposite direction
make sure the bobbin is inserted correctly into the bobbin case
there could be something wrong with the hook and hook race
and the machine may need some adjustment
Mar 06, 2013 | Sewing Machines
XR 6600 STICHES NOT SAME ON BACK AND FRONT OF FABFRIC
try using a different thread top & bobbin--make sure every thread guide is used
check the tension
make sure the fabric & needle & thread are compatable with each other.
Mar 20, 2012 | Brother Sewing Machines
How do you determine the rite needle to thread size
sounds like too much thread tension and mabe a #21 needle would help.
Jan 02, 2012 | Juki Storm Sewing Machines
Top thread on my Brother Limited Edition 350 Sewing machine keeps breaking. Having used the automatic cutter, the thread pulls up and out of the needle when I want to start sewing again. Also the machine...
rethread the machine
try a top thread tension of 3 or 4
change the needle
always keep a thread tail of 3-5 inches on top & bobbin thread & keep the thread pulled back behind needle before starting to sew
always keep the bobbin area clean of lint & loose thread
& check under the needle plate for lint also
you might consider having the machine serviced, since you said it sounds like a tractor
some needle & thread are not compatable-try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 04, 2010 | Brother Sewing Machines
I can not thread a bobbin to save my life. Help.
first, google your sewing machines name and model number and "manual" or "users guide" and you can find the link to the PDF download. Here is what I found:
1 Raise the needle to its highest position by turning the balance whell toward you (counterclockwise) and raise the presserfoot lever. Slide the button and open cover.
2 insert the bobbin so the thread comes out in a clockwise direction. Use bobbins intended for this machine. !CAUTION! Be sure the bobbin is set so the thread unrols in the correct direction. If the thread unrolls in the wrong direction, it may cause the thread tension to be incorrect or the needle to break.
3 Hold the thread end, push the bobbin down with your finger, and pass the thread securely through the thread cutting groove.
4 Replce the bobbin cover. Place the left tab in place then press lightly on the right side until the cover clicks into place. *insert the cover so that the end of the thread comes out from the back of the cover.
good luck and G.Bless!
Oct 16, 2009 | Brother XR-65t Mechanical Sewing Machine
I have a brother XR-37. I was in the middle of
Did you find the broken bit of the needle ?
It may be jamming the bobbin case area and hook. Remove the needleplate and bobbin case and clean it all out then report back with progress.
Sep 01, 2009 | Sewing Machines
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Brother XR65 twin needle threading
hi roscoepc1.....The threading pattern is identical to single needle. The only changes are that you now are threading 2 spools of thread, one thread for each needle. The only change that I reccommend, but not neccessary, is that while threading through the tension dial, lay your threads between separate discs, and not together between the same pair of discs. Your tension dial contains either 3 or 4 discs.......please update your post if you have any further information or questions.....good luck my friend
Aug 05, 2007 | Brother XR-65t Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
15 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
