Question about Norelco 8891XL Electric Shaver
I was cleaning my head (all 3 rotors) when i went to close and the head would lock close it just pops up
I have a dyson dc29 and I removed brush to clean now when I put back I dont get a click and it is not moving and pops right back out what am i doing wrong
You may have broken the Retaining Tab. First Clean the Pin Hole where it slides into to ensure it has the opportuunity to lock? Did you over stretch the locking Mechanism?
Oct 21, 2014 | Dyson DC29 Animal Vacuum
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Cleaners at bottom of pool dont pop up
Filter could be dirty?, clean or backwash.
or... You could have some debris: sand, grit, pebbles, etc. in your separate rotor valve assembly. There are small gears in there that turn the rotor plate, it allows for water to enter each set of pipes in a certain timed cycle. If those gears don't turn correctly, water won't flow alternately into those pipes that lead to each pop up head.
Apr 11, 2014 | Paramount Cyclean Automatic In-Floor Pool...
Both front wheel roters are stuck
What do you mean stuck? When I went to replace my rotors the first time on my 2006 I discovered 3 brass flat head screws in the Rotors. I literally had to drill the heads off to get them out. When I went to the parts store for replacements I discovered that these are only put on at the plant so when it is traveling on the assembly line the Rotors do not come flying off. THey are not necessary and do not need to be replaced
Nov 08, 2012 | 2006 Hyundai Santa Fe
1997 acura cl cant get the front rotors off
There is a phillips head lock screw in the rotor. Which gets very "stuck".
Once that is removed, they pop right off. You may need an impact driver with
a phillips (star) head like I needed. Got mine at AutoZone. Hope this helps.
Sep 03, 2011 | 1997 Acura CL
How do I split the DC head from the engine?
I am assuming that you mean the generator head from the engine. If this is so, 1st remove the end cover from the gen. head. You will see a bolt that goes through the rotor shaft to the engine shaft. The engine his a tapered shaft, that the gen head bolts to. 2) Remove the long bolt from the rotor shaft. 3) Remove the 4 long bolts that hold the housing ends together. 4) cut a length of rod that is smaller in diameter than the rotor shaft bolt and about 1/2 inch shorter. This will be used as a push rod to separate the engine shaft from the rotor shaft. 5) There are threads at the beginning(inside) of the rotor shaft. Most likely metric. Find the right size bolt, approx. 1" long. Screw in until contact with the push rod. (If possible, use an impact wrench to make it easy.) Tighten til the shafts "pop loose." One suggestion to keep the engine from rotating while doing this is to remove the spark plug, stick a length of small rope down the hole, leaving some hanging out, rotate engine until piston packs against the rope and stops the rotation. 6)now that the gen head is removed, the engine mounting end can be removed. Good luck.
Big Daddy
Jul 15, 2011 | Coleman Powermate Powermate 5000W...
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
97 ford aspire missing when idling..also misses when acclerating
With my 97 Aspire the Dist rotor pops up and rubs on the cap. The new rotor will lock on upon install but a few miles on the highway it pops up and will not lock back in place causing this exact problem. Standard Ignition company has sent 3 sets of cap and rotors from my car to R&D and they can not figure it out.
Sep 26, 2010 | 1997 Ford Aspire
2000 VW Beetle Hatch won't close tightly.
Try taking the battery out of your remote to see if it just still sending the signal????? You might have to clean your remote with contact cleaner. Also check the latch to make sure nothing is in the way of the latch????
Feb 14, 2009 | 1998 Volkswagen Beetle
Honda civic 2001
Remove rear wheels, remove rear calipers there will be two ten or 13 mm bolts on the back,(DO NOT LOOSEN THE LITTLE BLEEDER NIPPLE WITH THE RUBBER CAP ON IT!) pry the calipers back and off the rotors ,remove the old pads and get a c-clamp or big channel lock pliers and squeeze the caliper pistons back into the bores until they stop, now if your rotors are badly scored or rusty this is the time to change them there will be one or two #3 phillips head screws holding each rotor, remove these( you may need an impact driver with a phillips bit and a hammer) pull off the old rotors and reinstall the new ones after cleaning the rust protection off of them with brake cleaner and cleaning the rust from the hub where they sit., pull the rubber boots back on the caliper slide pins and lube them with clear silicon grease till they move freely, now use black hi temp grease to lube where the pads sit on the brackets(after cleaning the brackets of rust and dirt) and lube the backs of the pads (not the friction side make sure these stay clean!!) now reassemble and enjoy you just saved yourself a couple hundred bucks from the shop !! -jeff
Aug 09, 2008 | 2001 Honda Civic
Norelco 8891XL Electric Shaver Logo
23 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
