Question about Polaroid Televison & Video
DrM-2001G NEED MANUAL
SOURCE: ATT UVERSE-CONNECTION HELP! HELP!! HELP!!!
your a douche
Posted on May 12, 2008
mastersaintx
  • 928 Answers
SOURCE: looking for owners manual to downlad for polaroid
Click on the link below then click on User manual
http://polaroid.com/service/product.jsp?PRODUCT%3C%3Eprd_id=845524441764403&FOLDER%3C%3Efolder_id=282574488338773&bmUID=1227733689618&bmLocale=en_US
Posted on Nov 26, 2008
  • 226 Answers
SOURCE: replacement remote needed for Polaroid DVDR DRM-2001G
There is a group on the Web that messes around with what they call "JP1 remotes". All remotes of this type have a 6-pin connector that can be accessed/connected by a PC using a special cable. A parallel port, USB, and maybe serial RS-232C connection work.
Go here: http://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?5101,4
Read the article. I would suggest reading from page 1. You can program a JP1 remote to do all the functions specified in the graphic on that web page.
tom
Posted on May 11, 2009
  • 226 Answers
SOURCE: drm-2001g turn on says hello that all
If you are comfortable with electronics and using a DMM, you could remove the cover and check the voltage on the power supply. Likely you will find that a few capacitors on the power supply have leaked onto the board, or are bulging on the top. If you can replace them with equivalents, it may bring your machine back to life.
This unit runs extremely hot, and capacitors, electrolytic anyway, will dry out and fail. There is a 'gel' inside that just dries out. That is why the fan blows on the power supply in later models.
You might also have a failed hard drive. You can substitute a known good disk. Make sure the jumper settings are the same. If that is the problem, it will take a few minutes after you power on for the machine to finish setting up the disk.
tom
  • 226 Answers
SOURCE: vertical flipping
I bet you put it into PAL mode, the European standard. I believe that you can reset to factory default using the menu and it should be okay. If you cannot read and navigate the menu tree, then I think that if you hold the power button on after you start up, it will reset itself. I have not checked the doc to make sure of the last.
You can also get display problems if you pick the Y/R/G component setting in the menu. It is designed for connecting to a high definition using 3 different cables, one for each color. It only supplies vertical on one of those cables, and the TV just doesn't know what to do without the vertical blank signal from 'somewhere'.
Again, a menu setting.
tom
No audio on polaroid DRM-2001G
just unplug the power cable for few seconds
Oct 21, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Drm-2001g turn on says hello that all
tom
Apr 16, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Replacement remote needed for Polaroid DVDR DRM-2001G
You need to change the IR LED in the remote. I swapped in a new one from an old remote and it works great, no pointing and walking up to the unit with the remote.
Apr 08, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DRM-2001G weak remote
The range problem with the remote can be fixed by replacing the LED in the remote with a Radio Shack 276-143. The LED is a lot stronger and now the remote works a lot better.
You may also find that the 'receiver' inside the cabinet is pointed at an angle instead of directly towards the 'window'. You can trim the rubber(?) to allow it to point correctly.
Apr 06, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Televison & Video Logo
13 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
