Question about BenQ SP820 Projector
Bulb ballast for benq sp820 - BenQ SP820 Projector
Power automatic shut off after 5 seconds
check the lamp first
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | BenQ Office Equipment & Supplies
My lamp is not igniting??! how do i fix??
Hi Carl,
It sounds like you may have an issue with either the bulb or power supply. In either case, you will need the help of a professional service center. Feel free to send me an e-mail at david@digitronelectronics.com and I can have one of our techs contact you. Home
Jan 22, 2014 | BenQ SP820 Projector
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
Lamp died and remote does not work
I don't think the problems are related. The bulb shouldn't have failed as it is rated at 2000 hours. As for testing the ballast I don't believe that a conventional meter would do it. You would need a lamp testing device. For more go to http://www.myprojectorlamps.com/testing.html Since projector lamps or ballasts are not cheap you may want to have a a/v repair shop check your projector, because of the early bulb failure.
Feb 02, 2010 | BenQ PE5120 Multimedia Projector
Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Oct 23, 2009 | BenQ SP820 Projector
Benq 6200 shuts down immediately
did you reset the lamp timer? also may be the ballast.
Sep 28, 2009 | BenQ Office Equipment & Supplies
BenQ SP820 Projector Logo
69 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
