Question about GE JB968TKWW
JB968TKWW burner won't work - GE JB968TKWW
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Gas grill was washed now it won't light
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
Jul 13, 2012 | Grilling
My computer wont recognize my gp 840d dvd burner
Why won;t this burner work with my new windows 7?
Oct 10, 2010 | Iomega (33046) DVD±RW Dual Layer...
I have a bush dvd2039 and have put a dvd in and it won,t play and open and close won,t work either, have rebooted, unplugged and plugged back in and checked cables etc still nothing can you help please?
i take it your talking about a pc dvd burner if its not opening or closing i wouls say the cog/ruber band has broken you need to replace the driver (dvd burner)
Sep 21, 2010 | Bush DVD2038 DVD Player
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
GE JB968TKWW Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
