Question about Dryers
Where is the canadian shield realitive location
How many people live in the Canadian Shield? Need to finish work!!! AHHHHHHHH
srry i have no idea girl!!! i wish i knew but i do know that about 3.5 millon ppl live in canada
Dec 11, 2014 | Cell Phones
My car won't start so I need to know how to bypass the neutral safety switch in my 2002 Hyundai accent gl
These instructions are gor the 99 accent GSI. The steps should be much the same. ensure these instructions make sens to you before continuing. Keep in mind that you have now bypassed one of the safety features of the vehicle and it will now start in any gear. This can be left as a permanent fix. However it is my advice that this is used as a temporary solution to get you out of a bind and a proper switch should be installed as soon as one can be located and the cost covered!
Neutral safety switch bypass!
The cost of the switch and labor to replace with OEM parts is the mane reason for this work around. This is meant to be a temporary fix untill the propper swith can be replaced! The oem switch alone with no labour is $ 167.00 canadian funds.
Very limited tools or knowledge needed!
Material Needed
One 12 volt momentary switch, about 10 feet of 16 gauge wire, one inline fuse and a few crimp on wire ends. Total cost not more then $27.00 Canadian funds.
1. Remove air box for easy access
2. locate starter motor follow smaller of the 2 wires up to the under hood fuse box. ( black with white stripe)
3. Remove about .5 inch of the rubber shielding of the black and white wire
4. Attach 1 half of the 16 gauge wire to the now exposed wire.( for better connection solder if possible)
5. Attach other half of the 16 guage wire to constant 12 volt source. Place the inline fuse in this wire.
6. Route both of the newly attached wires threw the fire wall into the drivers compartment.
7. Locate a place to drill and place the switch. I used one of the blanks in the panel with interior light dimmer switch.
8. Connect your switch to the two wires and mount.
You are done.
Jun 22, 2014 | Cars & Trucks
Trying to purchase Flame Shield- 3 pcs for Red Stone Gas & Charcoal Grill Model 58813TS
The grill appears to be made in China. Try your local home depot type store and look for generic adjustable flame shields. In Canada I got mine from Canadian Tire.
Nov 12, 2013 | Grilling
What is the address and phone number of the canadian embassy in toronto
Canada maintains embassy offices in many countries _OUTSIDE_ of Canada:
http://www.learn4good.com/travel/canada_embassies.htm
If you are in Toronto, and need renew your Canadian Passport, see: http://york.cioc.ca/record/MKM2266 for location information.
Apr 02, 2011 | Computers & Internet
Where is the oil pressure sending unit on a 2005 4X4 Suburban 1500 5.3 liter
Removal & Installation 4.8L, 5.3L & 6.0L Engine To Remove:
  2. Disconnect the oil pressure sensor electrical connector. chevy_aval15_02-04_opsocket.gif
  3. Using J41712 sensor socket or equivalent, remove the oil pressure sensor.
To Install:
  1. Apply sealant GM P/N 12346004, (Canadian P/N 10953480), or equivalent, to the threads of the sensor.
  2. Using J41712 sensor socket or equivalent, install the oil pressure sensor. Tighten the sensor to 15 ft. lbs. (20 Nm).
  3. Connect the oil pressure sensor electrical connector.
  4. Install the engine sight shield.
8.1L Engine To Remove:
  1. Remove the engine appearance cover.
  2. Disconnect the electrical connector from the oil pressure sensor.
  3. Use a special socket such as J 41712 to remove the sensor.
To Install:
  1. If installing the old sensor, apply sealant GM P/N 12346004 (Canadian P/N 10953480), or equivalent, to the threads of the sensor.
  2. Using J 41712 or equivalent, install the sensor. Tighten the sensor to 22 lb ft (30 Nm).
  4. Install the engine appearance cover.
Aug 05, 2010 | 2004 Chevrolet Suburban
Canadian tire says tests fine. bought new battery,
open hood and check pcm wiring harness its located in the left back end of the engine compartment looking at it from the front of the vehicle. the wiring tends to become very loose
Feb 12, 2010 | 1994 Jeep Grand Cherokee
I have vacuum leaks .I have problems connecting the vacuum lines
you need to find your decal on the underside of hood or on the shield above the radiator cooling fan.
1997 PCED OBDII-A SECTION 1A: Description and Operation
Vehicle Emission Control Information Decal Each vehicle has a decal (Figures 1 and 2) containing emission control information that applies specifically to the vehicle and engine. The specifications on the decal are critical to servicing emissions systems.
typical decal
Figure 1: Typical Vehicle Emission Control Information Decal for 49 States Vehicles
Figure 2: Typical Vehicle Emission Control Information Decal for California Vehicles
Figure 3: Typical Vehicle Emission Control Information Decal for Canadian Vehicles. In addition to the tune-up specifications and procedures, the emission decal shows a color-coded (shown in black and white) schematic of the engine vacuum system. The color coding on the schematic represents the actual color coding on the vacuum hoses. However, there will be instances when a hose color does not match the color on the decal.
Decal Location Typical location of the decal will be on the underside of the hood or the radiator support sight shield.
Apr 04, 2009 | 1997 Ford Windstar
Audio
Hi, try logging onto the manufacturers website, click on download & support. Locate your mobo number and see if there is a Vista Driver. There may not be one available yet.
If there is not then purchace a PCI sound/audio card [realitively cheap] and install that. Just make sure that it is Vista compatable before buying it.
Regards mistyman
Oct 13, 2007 | Leadtek WinFast TV 2000 XP Expert...
Princeton Digital VL1916
In my years of working on LCD's, your inverter (basically like a ballast in a flourscent lamp) is bad/going out. Crack open the case and look for a big pink and white wire going to a pcb (usually located under a shield) and remove it and check for puffed capacitors. If there are some change them and that usually fixes the problem. If there are no signs of anything wrong on the inverter, get the numbers off the pcb and google or ebay the numbers, usually youll find a replacement realitively fast.
Sep 15, 2007 | Princeton Digital VL1916 19" LCD Monitor
Open Questions:
Dryers Logo
14 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
