Question about Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A, 9.6v 1000mAh NiMh Pk 2-Way Radio
Why does my kenwood TH-K2 fm transceiver will not transmit
I can not get it to transmit it tells me TX INH on the screen but want transmitt
    Problem Solver:
  • 12 Answers
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
Posted on Sep 07, 2014
3 Suggested Answers
  • 64 Answers
SOURCE: do you know where i can find a manual for a
Go to qrz.net, qth.com or just type the radio model on search engine : "kenhood th 22at diagram" will bring you a lot of places.
Posted on Feb 18, 2010
SOURCE: I need a belt clip of Kenwood TK-2160 vhf fm
Kenwood Part # is J29-0701-05 for the spring clip type. If you have a mailing address I'll send you one.
Posted on Apr 22, 2010
I have a KENWOOD TS-940SAT HF Transceiver that powers up with the TX indicator on, no power output and no receive.
Very little information about the situation of the transceiver is provided, it might be a complex one. The Kenwood TS-940SAT features a built-in automatic antenna tuner covers the amateur bands 160 through 10 meters. It is advisable for you to reinstall the transceiver and follow the right set up step to see if it works out eventually.
Apr 18, 2016 | Computers & Internet
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
manual.kenwood.com/files/B62-0790-10.pdf
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
? new bp 200 replacment for bp 199 will not operate my ic t8e radio
The IC-T8E is the Icom VHF / UHF Amateur (or "Ham") transceiver capable of wide-band AM & FM receive and 6 meter (50Mhz - 54Mhz) , 2 (144Mhz - 148Mhz) meter and 70 centimeter (430Mhz - 450Mhz) FM only transmit - when appropriately licensed by your country's communications authority.
RigPix Database Icom IC T8E
Any FM transmitter operating in those frequency ranges will be received and played thru the speaker - unless they are encoded with a squelch decode sub-audible tone or digitally encoded squelch control that does not match the one set to the IC-T8E. Program the squelch to be open or to match that of the transmitter so that the radio will play only when that particular transmitter is transmitting.
An FM transmitter operating in APCO25, DSTAR, etc. will not be decoded as these are digital signals that the ICT82 is not capable of decoding.
I was unable to locate any "BP200" radio you mentioned, so I can't comment on their capabilities or if they have an incompatibility in encoding, frequency, etc.
Mar 11, 2015 | Radio Communications
I have a Kenwood TM-D710A transceiver. It receives great, but when I go to transmit, it keeps resetting itself. I did a complete reset and reprogrammed, and it still resets itself when pushing the tra
Usually that is a sign of voltage drop when the radio draws current, make sure your power supply is large enough + about 50% more than the fuse ratings on the radio. Also check every power connection and make sure they are tight.
Sep 12, 2014 | Kenwood Radio Communications
Squealing sound
are you listening via FM transmitter function?
if so, make sure that you do either.
1) when watching the same DVD on both screens, disable the FM transmit on one DVD.
2) when watching separate DVDs on each screen, make sure that the frequencies are separate by as big a gap as you can make.
I had this problem and it was due to both screens transmitting on the same FM frequency and interfering with each other.
I also found that the lower FM frequencies stopped my GPS from working!
After altering the FM transmit settings (FM-TX) button on remote, it was all good.
Mar 12, 2014 | Eonon C1037 2x9" HD LCD In Car Black...
Open the frequency from 137-173mhz in th-th-k2e transceiver
google mods dk look under kenwood modifications. you will have to join membership is free basis a fee for premium downloads. you can get this mod free.
May 14, 2009 | D-Link DHP-301 Transceiver
Does not transmit
Model #? Name?
black box? make sure the tx rx are reverced on both ends.
Jun 21, 2007 | Black Box (IC109A-R3) Transceiver
Radio Communications Logo
180 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
