Question about Converse Watches
What is battery life converse ace watch? - Converse Watches
Do you have a watch battery comparrison chart?
An Internet search for "watch battery conversion chart" supplies hundreds of places. Here is one at random, the first one that showed up:
http://www.batteriesinaflash.com/info-watch-battery-cross-reference
Oct 10, 2017 | Watches
Tip
Watch battery conversion chart
Here is the link for most common watch battery (cell) chart and conversion chart:
http://www.lowcostbatteries.com/watch-battery-chart.asp
You can find useful information about other types of batteries on this site as well.
on Jan 20, 2010 | Watches
I have a Gucci watch which cost £630.00 and the battery lasted 17 months, is that the usual life span for a battery
it can be--their is no definite life span of a battery because everything has a different draw of power a simple watch can last years while more complex such as date/stop watch /backlight etc will draw and kill battery quicker
Jul 19, 2016 | Gucci Watches
What is the battery life like on the Martian passport?
Depending on what you are using the watch for it will have different battery life. Using the talk feature you should get around 2 hours, on standby about 7 days, the analog watch has a seperate battery that should last 2 years and charging the watch takes 2 hours to get a full charge.
Mar 06, 2014 | Martian Passport SmartWatch
Converse lowboy battery
Recommend you don't. Let a watchmaker do it/
Oct 14, 2012 | Converse Lowboy Thin Digital Watch - VR005...
My guess watch W15002G1 stopped working after the 4 years of loyal service. what could be the problems? I am thinking, it might be run out of the battery life. What do you think?
4 years is about right for the average life of a watch battery.
Just bring it in to any jewellery store and they will change out the battery for you for about $10 parts and labour.
Good luck.
Mar 27, 2011 | Guess Box Sets W15002G1 WW Watch for Men
For about a month, while the watch did keep time, the second hand only moved 4 seconds at a time. In other words, it would no move each second, just in 4 second intervals. Now it is not keeping time,...
Your watch is fitted with EOL (end of life). This does not mean end of watch life, but end of battery life. Replace battery and watch will work as it should. Rate me, please.
Feb 27, 2011 | Omega Seamaster 300M Mid-Sz 2551.80.00...
The movement on the second hand is jumping every 5 seconds instead of every second, however the time is still correct.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
Oct 13, 2010 | Omega Seamaster 2561.80 Wrist Watch
Hi i have a t-touch and i saw that the battery is Q/eol (end of life)...what do they want to say with it? If the battery dies the watch does too?
mcdevito75 here, I doubt very much it means end of life, unless it is actaully written on the watch or battery, Most Battery watches have access to change a dead battery, BUT!! there are sealed case battery watches too, these kind you find in vending machines, at McDonalds as giveaways etc.
Jun 24, 2010 | Watches
Screen stuck on battery life indicator
My guess is the battery was just changed? This watch needs to be cleared when the battery is changed. I recommend seeing a watch maker/technician to have the circuit board AC'd.
Sep 20, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
Watches Logo
18 people viewed this question
Top Converse Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Converse Watch Expert? Answer questions, earn points and help others
