Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Kitchen aid dioor removal. I removed the plastic door liner but cannot remove the door glass and surround to access screws for the door handle. Any tips are appreciated.
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: kitchen aid khms147hss0 microwave - handle broke
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Dec 05, 2009
How to remove and replace microwave door key
You must remove the inside plastic door liner that surrounds the glass. It just snaps into place so usea small flat blade screw driver to pry it out. You can then replace the door key.
If the spring has detached from the door a the outer door must be replaced.
Sep 30, 2014 | Panasonic NN-H965 Microwave Oven
Tip
Microwave Oven Door Handle Replacement
Door handle broken? Don't replace the entire door, or the entire microwave oven. As long as the the door facing is still intact, the door handle can be replaced at a fraction of the cost. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws should be visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can use to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
These are a few of the trusted sources that I have personally used that offer great service with competitive pricing. The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful.
on Dec 23, 2009 | Microwave Ovens
Replacing a whirlpool microwave door handle! got the new handle..how do I open the door up to screw the new handle on?
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 24, 2009 | Whirlpool MH7140XF Microwave Oven
Replacing door handle on microwave ge profile JVM2070BH02
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
Nov 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace the handle
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
Nov 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replace a handle on glmv168ks4
You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
Oct 27, 2009 | Microwave Ovens
How to change the handle for ge profile spacemaker oven model jvm1490wd003
You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches. NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
How to replace door handle on microwave frigidare fmv156dcc
You will need to access the door handle mounting screws and remove it to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife to carefully pry the plastic up and work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place and seats properly.
Oct 15, 2009 | Frigidaire FMV156DC Microwave Oven
Replace door handle on microwave Kitchenaid KHHS179LSS. I have the part.
You will need to access the door handle mounting screws and remove it to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife to carefully insert in the seam and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
Oct 15, 2009 | Microwave Ovens
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
