Question about Frigidaire Refrigerators
Frigidaire gallery 22.6 side by side model FGHS2342LF manual
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I see that you are looking for a manual for your Frigidaire Gallery refrigerator, model# FGHS2342LF. I have successfully located the owners manual for your appliance. Should you have any other questions, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Posted on May 16, 2014
22yooper
  • 828 Answers
SOURCE: frigidaire gallery model plhs267Za
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
Posted on May 30, 2008
  • 52 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
The Duff Man
  • 3 Answers
SOURCE: Freezer is cold but the frig side is not???
Hi Gotzd,  If you open the fresh food side (not the freezer), and look to the upper left side you will see a plastic shroud or cover. Behind that cover is a printed circuit board (p.c. board)   and a damper motor. That motor brings cold air from the freezer to the fresh food side. The whole damper assembly may need to be replaced. That also includes the cold controls for both sides of the "fridge".  Home Depot Parts and Accessories has the part available. 800.378.5830. Call, give them your model number, and the description, they will locate the part number for you. This MAY be the solution for you, it was for me. Hope this helps, better yet, Hope you've fixed already.
Steve D.,  Owner Handy Home Repair
Posted on Jan 22, 2009
heatman101
  • 43501 Answers
SOURCE: the freezer is thawing the
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 27, 2010
  • 116 Answers
SOURCE: Where is the thermostat located
Hi this is most likely the damper assembly not the thermostat, the damper assemly is on the left side of the refrigerator compartment in the very top corner up there, sometimes depending on the model this damper runs 3/4 of the length of the left wall there. This entire assembly needs changed.
Sean
Posted on Mar 28, 2011
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
Where can I get an ownes manual for the gallerries seies refrigeraor
This is a link to the Frigidair support site for manuals, you will need the Model number. Frigidaire Support. Hope this helps FixYa up.
Aug 02, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a frigidaire model frs 22 zgh side by side fridge build up ice on the evaporator? or the defrost heater is not working?
hi
one of the sensor is not working
you need to unplugged it and leave it to defrost for 6 hours
in order to release the sensor arm
Jan 09, 2011 | Frigidaire Gallery GLHS38EE Side by Side...
NEED A PARTS LIST FOR A FRIGIDAIRE GALLERY REFRIGERATOR AND DIRECTIONS ON HOW TO REPLACE THE WATER DISPENSER
use this site www.frigidaire.com to get your user manual
if you go on searsapplainces.com you can see your model and every part and your machine taken apart in each piece
as far as ordering parts try allbrands appliance parts they seem to be cheaper then any other you can also call them and have them look up which part you need
Apr 30, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No Manual
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Jul 22, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
183 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
