Question about Sharp el-531x scientific calculator
How to change to degree mode? - Sharp el-531x scientific calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Press the DRG key to cycle through the three angular modes.
Posted on May 12, 2014
How do I change the mode from Degrees to Radians?
Press the DRG key (top row) to cycle through the three angular modes.
Sep 18, 2012 | Texas Instruments TI-30 XIIS Calculator
OCT mode to DEG mode
OCT and Degree have nothing to do one with the other. Your calculator is in the Base-N computational mode. You have to change it to DECimal. Look for a key that has DEC marked next to it. You might have to press the SHIFT, 2nd or 2nd F key first.
Once the calculator is in Decimal numeration (press 8 or 9 to see if the screen displays the number entered) change the angle unit from whatever it is now (radian or gradian) to degrees. It is possible that it will show the DEG indicator after you switch to Decimal from Octal.
I am sorry but your not disclosing the make and model of the calculator does not help.
Jun 14, 2012 | Office Equipment & Supplies
When I hit dms function the answer comes out wrong the degree minutes = the degree and the seconds = the minutes how do I change it TI-84 Silver
At first, you have to use DEGREE mode and after that you can convert your angles into DMS mode. See captured image below
Oct 05, 2011 | Texas Instruments TI-84 Plus Calculator
When you are in "comp"
The "Deg" indicates degrees are the unit used for trigonometric calculations. You can use [MODE] [5] to switch to radians or [MODE] [6] for grade. [MODE] [4] switches back to degrees. This is independent of "Comp" mode.
Jan 16, 2011 | Casio FX-260 Calculator
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
Changing the mode in a casio
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Dec 06, 2009 | Casio FX-300MS Calculator
Just bought it its stuck on degrees how do you change it
Usually the option is degrees radians and grads. This is JUST the mode that the trig functions use. If you want angular measurement in one of the other modes, then you usually hit a function key and another key to set that mode.
Being in degree mode will not affect all the functions that are NOT trigonometric.
Aug 26, 2009 | Casio FX-260 Calculator
I need to change to mode to degress
Under the screen you can see atable of values at the right of which is written MODE followed by a small arrow.
If you want to set the degree as angle unit, you press the MODE key followed by 4 (as seen in the table I was referring to).
Similarly, if you want to set RAD as the angle unit you press MODE then 5; and MODE then 6 for GRAD.
However if you just want to convert a number displayed on the screen in RADs or GRADs into DEGs , you press SHIFT then MODE then 4. your number should be converted from the unit it was expressed in into degrees.
Same thing if you want to convert into RADs: SHIFT then MODE then 5.
Hope it helps.
Aug 02, 2009 | Casio FX-115ES Scientific Calculator
Don't know how to change it from degrees to radian mode
if you press the |mode| button (at the top right of the calculator) until you see Deg Rad Gra on the screen (I believe 3 presses of the mode button) and just hit the number below the rad option on the display. This will permanently change it to radian mode until you repeat this step, or clear the memory.
There is also a way to change to radian mode for just one operation if you will be mostly using degrees for example
at the bottom there is a DRG> as a shifted function. I would just recommend changing it in the way I initially outlined as there is less room for error when making calculations.
Apr 22, 2009 | Casio FX-300MS Calculator
Sin cos tan
37 is in degrees. so if your dealing with degrees you need to go to and change the mode. hit the mode button next to the 2nd button and go down to and change it from degree from radian by going to degree and hitting enter
Dec 05, 2007 | Texas Instruments TI-83 Plus Calculator
Sharp el-531x scientific calculator Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
