Question about HP Computers & Internet
How to unlock hp monitor
Connected monitor when it comes on the screen its locked
My F22 monitor had been appear OSD locked and i don't know how to solve it. Some buddy please help me!!!
important notes
1. what is displayed on the monitor comes from the system unit
2. possible features that could be displayed on the monitor are screen savers or splash screens
3. attempting to log on a computer with a screen saver passcode could lock the system by displaying the word locked requiring unlocking
procedure of unlocking a passcode
1.Once the system locks, would require to reset the password.
2. another function could be displayed on next to the lock icon prompting unlock or reset
3. in the absence of a display of unlocking the password, continue to enter the wrong password and hiting the logon button in a space provided next to the unlock icon prompt
4. severall attempts would prompt for a reset functionality.
5. at which instance would display a password hint of what has been locked.
6. the password hint provided must be guessed correctly to allow a reset functionality.
7. once hint provided allows for reset would prompt the user to create a new password
8. create a password with a hint as a key to reseting any future locked screens.
9. the screen could be operated without a password for an alternative, only made possible during after unlocking the locked screen. instead of creating a new password and hint, choose to disable screen savers altogether.
Dec 06, 2010 | AOC F22 Monitor
Screens not working
If the laptop gets turn on and if you are able to hear the windows start up tone then the display drivers may be corrupted. So connect the laptop to external monitor. If the display comes on the external monitor then you can perform the system restore.
It will get your display back to normal.
Please get back so I can provide you more steps to get the display back.
May 31, 2010 | HP Pavilion dv2000t Notebook
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
I need to unlock my monitor
Here is a link to the manual for your AOC 22" monitor.
When the window opens you will see "pdf downloads" on the right side of the page. Click on your manual and download it.
Hope this helps to unlock it.
http://us.aoc.com/support/manuals_drivers
Nov 13, 2009 | Computers & Internet
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
My computer screen
press all keys simultaneusly for 5 seconds and leave when small window shows massage" keys unlocked" then window dissapers
Oct 28, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Osd locked
You can download the user's guide for this monitor from hp at:
and picking the "monitor user's guide" link.
Details of locking/unlocking OSD are on page 32.
Oct 26, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
