Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
WONT START AND LIGHTS FLASH
OUR RINNAI RCE 318 WON'T START AND THE LIGHTS FLASH
  • Anonymous Mar 23, 2014
    rinnai 1000f is flashing a code 53 and wont start
  • 139 Answers
Try interrupting power to reset.if it still doesnt work consult manual for code to flashing light sequence.also make gas supply is on
Posted on Jun 25, 2009
How to fix gas heater Rinnai RCE-229H?
get a gas fitter in to fix the problem as gas is less forgiving than electricity
Jul 19, 2015 | Rinnai Heating & Cooling
Rinnai natural Gas Heater 25 TR (Avenger RCE 670)
this is all I could find it looks like an earlier model, but it may be helpful. sorry it is such a long link. it's the download link for the manual, hope it helps.
http://www.google.com/url?sa=t&rct=j&q=rinnai+natural+gas+heater+manual+avenger+RCE+670&source=web&cd=3&ved=0CC4QFjAC&url=http%3A%2F%2Fwww.finesgas.com%2Fproduct_extra_files%2FRinnai-RCE-592.pdf&ei=rzZgUMbfKpLI9QTwx4DwCQ&usg=AFQjCNGPoBENsIVWy_-1GG94mowsXBSosg&cad=rja
Sep 24, 2012 | Rinnai Heating & Cooling
Can I convert a rinnai rce-229a from propane source to natural gas source
It should be. You should be able to replace the oriface and the regulator. Propane is at a higher pressure than natural gas.
Aug 01, 2012 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Hi I have an old Rinnai RCE 417H natual gas unit
needs a service a clean and check of the ignition secquence. should only have green light for power and red light for Lighting. large screen can be bought from Rinnai part supplies
Jun 14, 2011 | Heating & Cooling
My rinnai rce 229 will only start on timer button it will switch off on on/off button but then will not switch back on with on/off button it will only switch back on with the timer button help.
To cancel the ON TIMER here's what you need to do:
Press the "ON Timer" button or press the "ON-OFF" button.
The setting will be canceled and the timer indicators will go out.
TO RESET THE UNIT
The ON Timer will be canceled if the power plug is removed from the power point, a power failure while
the appliance was in standby mode, or if the ON Timer setting is canceled. "00" will flash on the digital
monitor when power is reinstated. Pressing the ON button and starting the unit will delete the =00".
Hope this helps you.
Apr 08, 2011 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai gas heater model RCE-318H piezzo keeps trying to light unsuccessfully times out after about 30 secs.then pilot light led stays lit up. any ideas.?
Real odd one as if ignition fails this unit is designed to flash various lights to give you an idea of what the fault is. Also this usually happens after about 10-15 seconds. I'm going to have to ask you to clarify that no other lights flash. If I had this fault exactly as you descibe, after running some basic tests to check gas supply and any obvious damage or burnt out components I would change the the main PCB as a start and the control PCB as a plan B.
Aug 06, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Cheap charlie pellet stove/pel-pro runs for 10min then shuts down
The auger is controlled by a T-stat on the side of the combustion chamber. Open the side of the stove and you can see the auger motor and the thermostat that feeds it. It has a manual reset button on the back of the thermostat, press it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 05, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
456 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
