Question about Frigidaire GLEQ2152ES Electric Dryer
Why is dryer get very on on top of outside of dryer
  • Frigidaire Master
  • 5,323 Answers
SOUNDS LIKE THE BLOWER ELEMENT IS NOT FUNCTIONING PROPERLY DUE TO RESTRICTIONS? CHECK UR VENTING? AND LINT BASKET IF ITS FULL UR INSIDE OF UNIT MAY BE FULL OF LINT ALSO BAD BAD AND BAD CAUSES OVERHEATING AND THEN SHUT DOWN?
Posted on Dec 20, 2014
Inside the drum, one of the metal things is loose. It appears that it is held on with screws, so they are probably loose. Could you tell me teh easiest way to access the outside of the drum so I can...
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum and tighten the baffle screws. But before the top cove can be lifted, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the baffle screws are on top to tighten it. Reinstall the top panel and the front panel by following the removal steps in reverse order.
May 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Removing top of dryer to get to the drum
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum. But before that, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
May 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to I get to the drum? The fins in the drom have come unscrewed and fallen off. I need to get to the outside of the drum and screw them back on.
Access to the outside of the drum requires the removal of the front then the top panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Rotate the drum until the screw holes appear at the top of the drum and screw the baffles back into position.
Note: This guide is for Maytag Sloped-Front Dryers.
Apr 19, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
I have a g e clothes dryer The top of the dryer
usually a clogged or obstructed vent hose or outside vent causes this. Also check inside the dryer (when cool) to see if there is lint building up inside, hindering air circulation.
Nov 02, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer gets too hot, so hot you cannot touch outside top of thr dryer. drum sizzle if you sprinkle water on it.
Inside back panel on the outside of the heater element enclosure there are over heat thermostats..round with two screws...
Oct 06, 2009 | GE Dryers
Need to hook up new plug
Red on one side of terminal block, white in middle, red on other side. The green is attached to outside using screw to to top left of terminal block compartment on outside of cabinet. Hope this helps!
May 18, 2009 | Kenmore 62602 Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Lint Blows Out the Top!
it should be curled but not kinked.make sure air is blowing outside with force.also make sure to pull dryer good distance away from wall.
Apr 05, 2007 | Whirlpool LEQ9858P Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
